440 starter
deereford
06-29-2007 06:06:34
I have broken 2 bendex springs this year on my 440. It has been converted to 12 volt. Does this cause the starter to engage to forcefully? I also have an MC with this conversion that has been no problem at all. Thank you very much in advance!!
buickanddeere
06-29-2007 07:11:26
 Re: 440 starter in reply to deereford, 06-29-2007 06:06:34
The 440, in particular the late high HP version of the 440 gasser is a larger engine with a higher compression ratio than the M. Time and time again we ask here. Why not repair the electrical, fuel or ignition system? Instead of trying to compensate with higher system voltage? The 12V on a 6V starter as you have found, gives the bendix, pinion & ring gear a smash 2X to 4X more intense than the factory 6V system does. See previous posts here on setting up a 6V system to start any Dubuque gasser in any weather.
