4430 versus 4450?
hills7020
06-28-2007 22:44:44
Hey,I am looking at these two tractors. The 4430 has Quad-range,cab,new tires and 4200 actual 1 owner hours. He wants 18,900 for it. I believe it is a 1977 model. The 4450 is also a Quad-range,has a cab,90% tires and has 5010 actual 1 owner hours (from the same farm). It is a 1984 model. They are asking 29,500 for it. Both are very nice looking tractors. The original owner says both have been maintained well and have good history with reliability. He used the 4450 for tillage work and chopping,and did hay work with the 4430. Both seem very straight. My question is,which would you rather have? I have only owned one Deere before (hence 7020 in my name) and would like to know which one is the better tractor? I talked to the local Deere dealer and they told me that either one are good but the 4450 is better,is that true? Any help on people who have owned these models would be greatly appreciated. Reliability,power,features,etc. is what i'm interested in. Also,money difference doesn't bother me if the 4450 is the better machine. Thanks in advance. Richard
Mike M
06-29-2007 07:48:53
 Re: 4430 versus 4450? in reply to hills7020, 06-28-2007 22:44:44
Buy them both ! They sound like good 1 owner tractors.
If you can only afford the newer one get it.
msb
06-29-2007 06:32:42
Hours should weigh little in this decision. Seals dry out and other things happen from non use so the hours on the 4430 is pretty much a non factor in my opinion and I own 2 4430s. For another $10,000, an easy decision--buy the newer one.
ram ranch
06-29-2007 06:20:55
I have both 4430 and 4450. once we got the 4450 to only duty the 4430 had was hauling manure and blowing silage. The torque rise and pull from the 4450 in the field was alot better,and nicer to drive and operate. Granted both have been really good tractors, Bought them both new just changed oil and general maintance. If i had the choice I would go with the newer 4450. The price is a little step, but if you know where they came from and how they were taken care of. What kind of price can you put on that? not like your buying from a jockie or consignment auction, buyer bewhere. just my 2 cents.
JD @ Antique Acres
06-29-2007 05:34:43
I would second what TX Jim said, particularly the hard starting in cold weather. Also I might add that the price seem a little high, for my area anyway.
Tx Jim
06-29-2007 04:02:36
 Re: 4430 versus 4450? in reply to machinery-man, 06-28-2007 22:44:44
IMHO the 40,50 and 55 series JD tractors are the best JD ever built. I have a JD 4255 with 9300+ hrs on it that has been very good. The 4430 doesn't have as good seat suspension,not as good steering,won't start as easily below 40 and the differental is not as beefy as later models. That being said I'd buy the 4450 if I were you. Tx Jim
