1957 720
iowa_tire_guy
06-28-2007 16:14:58
I was able to buy a dream tractor last weekend. It is a 720 diesel with a gas starting engine. It is just like the one I grew up on. Pull started and drove it home Sunday. Now am working on the gas engine. It does not have a spark which from previous discussions here tells me that the coil pack is suspect. I unhooked what I though is the kill wire and still no spark. My questions are: how do I check them out and where is the most economical place to buy them if I need them?
iowa_tire_guy
06-28-2007 18:56:39
 Re: 1957 720 in reply to iowa_tire_guy, 06-28-2007 16:14:58
Thanks guys for the information. It was just what I was looking for. The supper bell rang before I got very far in the search for no spark so I will dig deeper in the morning. And indeed I was thinking a magneto when I unhooked the power wire thinking it was a kill wire.
Thanks again and I may be back. Got a tire question you need answered?
ITG
John T
06-28-2007 17:05:50
Kill Wire ????? ???? if you unhooked the wire that feeds voltage to the distributor from the Ignition Switch shes sureeeee eee never gonna run that way. If its coil(s) have that classic burned electrical smell they may well be shot as happened when the ignition was left on so often. See if when you turn on the ignition switch theres voltage on a wire to the power input stud and if so hook it back up. If the coils are okay the points could still be a problem, better check n clean n gap them. Those coils have a primary winding which gets power from the input stud (when ignition on) and gets its ground via the closed points while its high voltage secondary has one lead to each of the 2 plugs it fires.
Then theres that small coil of wire ballast resistor on the ignition switch which drops the coil voltage down to around 4.5 volts when running but by passes it for battery voltage to the coils while cranking you may have to deal with
Check for input power when the ignition is on and then check the points and then move on to checking the coils, but are you sure BOTH coils are bad cuz if one was still good at least 2 of the plugs ought to still fire. To test the 2 plugs out of the common coil both need connected and sides grounded or at least one side grounded.
Im a lil rusty on pony ignition compared to Blksmoke and Frank n some others but you gotta have voltage to the coils and good coils and then good points n condensor.
John T
buickanddeere
06-28-2007 17:48:08
 Re: 1957 720 in reply to John T, 06-28-2007 17:05:50
I wonder if Iowa is thinking magneto instead of a battery ignition system? Try watching the ammeter with the ignition switch on the 1st position. There should be a red dash light on. With one point set closed there should be 3-4amps, with both points closed the ammeter should be dragged back 3 to 8 amps. Has some intrepid tinkerer replaced the dash switch? The starting engine, 6V & 12V & gasser and 24V diesels all use different switches. The switches all do however look very similar.
Roy in georgia
06-28-2007 18:08:23
 Re: 1957 720 in reply to buickanddeere, 06-28-2007 17:48:08
I guess u saw I figured out my gov. problem after fat boy said " No I didn't adjust nothing"
buickanddeere
06-28-2007 21:03:17
 Re: 1957 720 in reply to Roy in georgia, 06-28-2007 18:08:23
r.i.g What is the current status of that 1010 and what was monkeying up the govenor's ability to control the carb's throttle butterfly?
b&d
