In a dilemma need your advice
Tjh72
06-28-2007 09:03:19
I have a 1977 John Deere 2440 with a 146 John Deere Loader on it. I noticed several weeks ago that the oil light was flashing on and off. I took it to a friend of mine that owns an equipment dealer to look at the problem. He found several things wrong with the engine and thinks the best way to fix it is to re-build the engine or buy a short block from John Deere and replace it. This is not cheap to do and I know he is not overpricing me because I looked into it myself. I have been thinking about getting a newer, little bit larger tractor and I am not sure if I want to keep this one. I have been looking at a 2555 or a 2755 tractor. I use the tractor for baling hay, planting corn, drill soybeans, etc� So, here is the question. In your opinion would you repair the tractor or would you sell the tractor as is and get what you can for it? I know ultimately this is a personal decision, but I have received go advice from all of you on this forum so I thought I would ask your opinions.
Thank you,
Tjh72
Mike M
06-28-2007 09:55:38
 Re: In a dilemma need your advice in reply to Tjh72, 06-28-2007 09:03:19
What exactly is wrong ? just worn bearings ? water or fuel in the oil ? If it ain't knocking yet try rolling in some new bearings and by some time.
tjh72
06-28-2007 11:50:19
 Re: In a dilemma need your advice in reply to Mike M, 06-28-2007 09:55:38
The engine only had 5 pounds of oil pressure at idle. When they took the oil pan off to check the oil pump a bearing dropped of the engine (not sure where from). They could also tell that antifreeze has been in the engine on the crank. They have not got very from into it but it has problems.
Tjh72
Mike M
06-28-2007 12:08:50
 Re: In a dilemma need your advice in reply to tjh72, 06-28-2007 11:50:19
I guess it depends on how well you know that tractor if it is worth fixing the engine ? I'd hate to spend alot on an engine only to find out it had alot more problems. No guarentee on another one if you buy it used either ? I had a fellow tear out the hi-lo in a 2840 and it needed a clutch too. Ended up fixing it and then a year later the sleeves let loose leaking antifreeze into the oil. So then he HAD to fix the engine. It wasn't very bad as it was caught early.
In the end it may of made more economic sense to of sold it to a junk yard the first time because with the engine running they offerd $3,000 for it. That wasn't a bad offer ! I'd check out selling it as-is to a scrapper verses fixing it and also see what you get for a trade in ? You may also price a used engine too. At least then it would be running and would have more trade in value.
machinery-man
06-28-2007 09:25:33
If you are not able to do work yourself I would say you're going to spend a boatload of money. In this case you may be able to describe your item and sell as is and put on another good unit. You might have the option keeping the loader if you get a similar tractor. Just and opinion.
