4030 Hydraulic Remotes
wolfman
06-27-2007 19:34:43
My 4030 Remotes won't let the round baler door stay closed. Begin a bale and in no time, the door will be ajar. For the last couple years, I'd hit the control lever and the door would close-might have to do this twice per bale. Now it just won't hold at all. Some valve? Some beach! Ideas? Thanks.
Tx Jim
06-29-2007 04:27:13
 Re: 4030 Hydraulic Remotes in reply to F-I-T, 06-27-2007 19:34:43
Wolfman the SCV's have two pressure and two return valves in each that are a PIA to adjust correctly. I would suggest removing and finding a good JD technician to repair them. When I first started custom rd baling I had a 4030/open station. I like SGB's much better for rd baling. Tx Jim
Tx Jim
06-28-2007 04:27:34
 Re: 4030 Hydraulic Remotes in reply to Kyle Miller, 06-27-2007 19:34:43
Try reversing the hoses in the same coupler. Get a 3000 psi gauge and check bleed off time. Could possibly be baler gate cylinder or baler valve leaking. Close gate and un-plug hoses and bale a bale. Tx Jim
wolfman
07-04-2007 18:52:30
 Re: 4030 Hydraulic Remotes in reply to Tx Jim, 06-28-2007 04:27:34
Thanks again TX Jim. I reversed the hoses in the same coupler and baled 30 bales yesterday and it worked as it should. You hit it right on.
wolfman
06-28-2007 18:31:52
Thanks for tips, Jim. Baler works good with the 3010; the 3010 struggles but the gate stays closed. I'm thinking the 4030 has hydraulic issues. One set of outlets are just about impossible to connect; both sets of outlets let the gate become ajar.
