830 A little more info
Michael Sheik
06-27-2007 18:57:00
I talked with the previous owner again and he mentioned that you have to slow the engine to very low idle to engage the PTO. I always thought this was the way you were supposed to do it to keep from tearing anything up. On my IH1066 the PTO is hydraulically engaged. Not familiar with this 830 so is it hyd. engaged or is it gear meshed like the old 9N? He is a farm boy so I wouldn't suspect that he doesn't have a certain amount of sense when it comes to taking care of machinery.
Mike M
06-28-2007 04:48:21
 Re: 830 A little more info in reply to Michael Sheik, 06-27-2007 18:57:00
Sounds kinda like the 2 stage clutch is sticky ? If the facings are warped or oily they will do that,could even be out of adjustment ?
buickanddeere
06-27-2007 20:11:34
Which model of 830? 1950's or 1970's? Is the pto independent of live with the two stage clutch?
Michael Sheik
06-28-2007 04:32:08
 Re: 830 A little more info in reply to buickanddeere, 06-27-2007 20:11:34
Sorry, I was posting about it yesterday and just assumed but it is a 1975 model approx. 40 hp 3 cyl. diesel utility tractor.
jdemaris
06-28-2007 06:18:42
 Re: 830 A little more info in reply to Michael Sheik, 06-28-2007 04:32:08
As far as I recall, the 830 only came with a two-stage clutch PTO - or a ground driven PTO. Even when working correctly, you usally have to idle the engine down and hold the clutch down for a while before engaging.
The U.S. built 1020 and 300 - which is almost the same tractor as the 830, has different hydraulics and was offered with a hydraulic independent PTO as an option.
Roy in georgia
06-27-2007 20:38:08
it's been a while since I was on here so how's the leg?
buickanddeere
06-27-2007 21:29:12
 Re: 830 A little more info in reply to Roy in georgia, 06-27-2007 20:38:08
Thanks for asking.
Air cast off a week ago as per surgeon's orders. I had been lightly loading it for a week prior and working it through range of motion. Walking with a cane takes a surprising amount of stress off the leg/ankle and improves stability. The ankle is weak, stiff and makes popping/crunching sounds but is improving. I trust it enough to climb stairs but not to walk down them. Some torn ligaments & tendons along with the bone. Walking outside on rough ground in order to water the new trees etc is nerve wracking. Don't want to go over on the ankle again. It isn't safe in the house either as the children spill slippery but invisible booby trap beverages on the floors. The youngest is always building machines from kits. The small sharp camouflaged pieces in/on the rugs, carpets or on the hardwood floors are the most dangerous. The worst part knows the break was an incident, not an accident. I preach safety then go and three times keep quiet about hazards in 10 minutes. Rather than ruffle feathers by insisting on talking a couple of minutes longer to do the job right. All in all however in the grand scheme of things, I can't complain. The injury could have been much worse. The medical treatment was pretty good. Lots of sick days to use instead of hobbling into work. Maybe somebody here will work a little safer after reading this. The sound of the fibula going SNAPPPPP will stay with me for a while. While it�s all in my head, I swear I can feel the bone�s titanium plate wearing against my skin from the inside out.
jdemaris
06-28-2007 06:15:29
 Re: 830 A little more info in reply to buickanddeere, 06-27-2007 21:29:12
I can say for sure that I can just about always feel my steel plates and screwheads. I've got plates on both legs just about the ankles. Broke both legs literally in two, over 10 years ago - from a wild ride on a John Deere 3020 that lost its brakes, jumped out of gear, had no steering, etc. I should of known better, I can hardly call it a true accident - since it could of been prevented. One note though - after surgery I was on crutches or canes for 6 months - and my back had never felt better. Using crutches really stretches it out. I've had doctors suggest going back in to my legs and taking the screws out - but so far, I'm too chicken. I worry they'll make things worse.
buickanddeere
06-28-2007 17:54:30
 Re: 830 A little more info in reply to jdemaris, 06-28-2007 06:15:29
I hope the mends continue to work without complications. I started to cringe then roll up into the fetal position, holding my leg as I read about your quaduple break. May I ask the details of the precursers to the incident and were the breaks from landing or having something land on you?
jdemaris
06-29-2007 06:20:09
 Re: 830 A little more info in reply to buickanddeere, 06-28-2007 17:54:30
Well, it goes like this. I'd just bought an old farm that sits on top of the steepest hill in the area. I was in the process of moving some of my three-point hitch equipment over there, one piece at a time with my little IH B-275 tractor. Each round trip was four miles. Then, my neighbor who lived next door to my prior residence suggested I take his Deere 3020 to move my stuff - since it would be much faster. This is where my stupidity kicked in. This guy was a "failing" dairy farmer. Everything on his farm was falling apart, taxes not paid in years, sick cows, owed money all over town, never fixed anything, etc. etc. The 3020 was in pretty bad shape. But . . . I took it - why, I'm not sure? Maybe I figured it would go faster, and maybe I didn't want to hurt his feelings. Well, while climbing the hill - perhaps half-way up - the 3020 SynchroRange trans jumped out of gear, then the engine stalled, then I had absolutely no brakes, no steering - and before I could think much about the whole deal - I was flying backwards, downhill, with a heavy three-bottom plow on the back. If you're familiar with well-used Deere 2520s, 3020s, and 4020s - when the engine dies you lose ALL brakes and steering - not just the assist. So - with little time to think - I jumped off the tractor while moving pretty fast. How fast, I don't know - but when I landed on the road - apparently moving sideways at a high speed, both my legs snapped right in two. I didn't even know it at first. I sat and watched as the tractor went off the road and crashed into a tree. Then, I tried to stand up - and both my legs gave out from under me. Then I looked down and saw both my feet doubled over and my bones sticking out. At that point, there was no pain at all. My wife found me a few minutes later. I dragged myself into her car and she took me to the emergency room. I passed out on the way to the hospital. Got emergency surgery with plates, pins, etc. on both legs. Also found out one heel was completely shattered which there is no fix for. Six months later, after a lot of 24 hour a day pain, one doctor suggested amputation of my right foot - but I refused. Still got it. That's it. I'm certainly gimped up a bit, always limp and cannot run at all. But, I do walk and I am alive - so that's a plus. I had lots of people tell me I was an idiot to jump off and I should of rode it out. All I can say is - you had to be there - and there wasn't much time to think it over. The tractor crashed pretty hard right after I jumped. I suspect I'd be worse off had I stayed on. By the way - on the subject of doing stupid things. I worked as a mechanic and a house builder all my life - and up to age 40 had never been even slightly injured. Then - I did several major stupid things. Before this 3020 accident - I converted a Ferguson 40 tractor over to 12 volt for a guy. When he came to get it, and I was warning him on how fast it started - he accidentally DID start it and ran me over - right over my right shoulder and creased my neck. Wound up having a broken neck with two fractured vertibrae, broken shoulder, and several broken ribs. Had to get my neck fused - first operation failed, second one worked. It took over a year before I would walk on my own. So - stuff happens, I guess. Nobody to blame but myself - unless I want to complain to the Almighty about short-changing me on brains. When I was a Deere mechanic, we had several good customers with years of experience get killed in similar situations - and most times it was older farmers who certainly knew better. So, compared to them, I got a better deal. In regard to your new steel. I've been told that some people tolerate it well, and some don't. Very often they will go back in and remove the stuff if you want. I've considered it, but haven't done it yet. I don't find the idea of some Doctor attacking my legs with a Makita screw-gun - very appealing.
