First reduction gear model A
Glen in Michiga
06-27-2007 11:02:06
It says in my manual to check for water in the first reduction gear cover by removing the plug from the cover. Can someone tell me where this is located? Thanks
kendak
06-27-2007 11:31:21
 Re: First reduction gear model A in reply to Glen in Michigan, 06-27-2007 11:02:06
It would depend on year of tractor...early styled "A" did not have a drain plug in red. cover...unstyled did"t either...Kent
Bob
06-27-2007 11:15:54
To check for water, you would loosen the drain plug, which is at the lowest part of the reduction cover. (Oil floats on water, so any water will be at the very bottom.)
