3020 Trans
Mike in DePere
06-27-2007 05:12:18
We had to pull the tractor over to the shop down the road about a mile, we overhauled the engine now when we try to shift it it seams to be locked in gear when you try to put it in park and let the clutch out it is locked in two gears cannot get it to shift to reverse. What did we do to it to cause this problem
buickanddeere
06-27-2007 20:08:29
 Re: 3020 Trans in reply to Mike in DePere, 06-27-2007 05:12:18
You didn't read the operator's manual.
Bob
06-27-2007 09:43:02
Mike's correct. Towing it (without the tranny in "TOW", engine STOPPED) overheats the gears and upper transmission shaft because the gears are spinning at a different rate than the shaft, and there's no lube to lube/cool them, 'cause the tranny oil pump isn't operating.
A gear, probably the "low pinion" has "friction-welded" to the shaft.
Time for a MAJOR tranny overhaul.
Mike M
06-27-2007 05:25:14
Did you tow it in the TOW position ? If not likely you just galded a shaft and bearings in the tranny.
