4450 too much power?
farmking1964
06-26-2007 21:23:12
Hello. I recently purchased a John Deere 4450 tractor. It is four wheel drive with the Quad-Range transmission. I don't know much about it's history,but it is showing 7300 hours. I am worried about it's horsepower though. It seems to be too strong. It smokes ALOT of black smoke too. The seals are on the injection pump,but i'm thinking it's either been messed with or has a bigger pump. I know that I shouldn't be complaining about a tractor being strong,but i'm thinking long-term here. Should I have a mechanic check it or just leave it alone? Thanks in advance! Ronald
G/MAN
06-28-2007 07:43:12
 Re: 4450 too much power? in reply to farmking1964, 06-26-2007 21:23:12
Excessive smoke does not necessarily mean excessive horsepower. As was mentioned, it could be a problem in the pump or simply excessive wear in the pump and nozzles. As those parts wear, the tolerances get out of whack, and you end up getting more fuel than you should. Checking the aneiroid is a good place to start. It regulates fuel delivery based on boost pressure, and is there specifically to stop excessive smoke under acceleration. It holds fuel delivery back until there is sufficient boost and air coming in to burn the extra fuel. Put in one the dyno, and be prepared to remove the pump for service. The nozzles should also definitely be removed and tested, and it's extremely likely that you'll be replacing those, too.
Tx Jim
06-27-2007 04:31:40
 Re: 4450 too much power? in reply to olddog, 06-26-2007 21:23:12
It shouldn't blow much black smoke. Problem could be turbo-charger or air filter. Maybe you should have it dynoed if you think it's been turned up. Tx Jim
farmking1964
06-27-2007 08:56:44
 Re: 4450 too much power? in reply to Tx Jim, 06-27-2007 04:31:40
It only smokes black when I open the throttle up. I think i'm on a pro stock sometimes,lol. It has got to be way over it's horse.
buickanddeere
06-27-2007 11:31:57
 Re: 4450 too much power? in reply to farmking1964, 06-27-2007 08:56:44
Is there a mechanical aneroid (hemeroid) on the injection pump? Full fuel delievery should not occur until the turbo has spooled up enough to build boost.
