530 wont charge
Bob from missou
06-26-2007 13:10:07
my mother in law has a 530 john deere that isnt charging ( i dont think) -when i pull the positave cable off while it is running it dies. my father in law had some on convert it to 12v altenator( the type a chevy has or had) there is only 1 wire going to the altnator and it is the hot lead. the old toggle type switch is still on it. i have had 2 guys that cant figure it out. any ideas would be very helpfull
thanks in advance
bob
bob from missouri
06-27-2007 18:18:38
 Re: 530 wont charge in reply to Bob from missouri, 06-26-2007 13:10:07
im going to go give it a good look over friday. and to me it is a mess but im not to up on the electronics. the only thing i know for sure is it is a chevy type alternator, 2 prong plug in in the side, 1 bolted lead on the back of it (and it is hot all the time???? according to my test lamp)in the long run i probably be better off getting a factory alternator , new switch and schematic. anyway guys thanks for all the help, and i will give it a good look over friday i hope
thanks again
bob
machinery-man
06-27-2007 06:37:30
To each his own, but I always found that the later model generators did a good job on the tractors...I would say to rig up something like you have you have to be sure to have the switching designed properly, power on to alternator, wiring set for the amp guage and switches. I know it will work must most of the setup I"ve seen are a horror story, jury rigging the existing regulators, wiring, you name it. My suggestion if you"re keeping the alternator would be to wire similar to the 1020 or something factory with an alternator. Good luck....
John T
06-26-2007 13:45:16
First thing, I dont advise that pull the battery cable off test, that may have already done some harm??
Next, if the alternator is a GM 10 SI 3 wire unit, it needs to be excited via its lil side No 1 terminal (a diagram or my writtn instruction can be posted of how to wire it up if needed) to work UNLESS its been converted to a true One Wire Alternator.
Also most alllll l alternators require negative ground while the tractor was orignally Positive ground. Whats the tractor now????? ???? If at Positive ground you may have let the smoke out of the alternator already !!!!! !!!!!
If its a GM 10 SI 3 wire alternator (has rear main output post and 2 lil side wire terminals labeled 1 and 2) Id insure the battery is connected at negative ground and then wire it up correct (hope alternator isnt already fried) n see what happens.
lemme know
John T
OTISR
06-26-2007 14:06:41
 Re: 530 wont charge in reply to John T, 06-26-2007 13:45:16
Simplest way to check alternator is to attach voltmeter to battery when running engine at more than a idle. If it is at 13.5 volts or more it is charging. Shouldn't be more than 14.5. If no change from running to not running then it is not working.
