730 D 12V starter conversion
JSR 730
06-26-2007 11:02:33
I am looking for someone to send my 24V starter off my 730 D and have it converted to 12V, or is there a off the shelf 12V starter that would work. Thanks.
JSR 730
06-29-2007 11:36:24
 Re: 730 D 12V starter conversion in reply to JSR 730, 06-26-2007 11:02:33
So will a 42MT starter work in place of the original starter? If so, was the original starter considered CW or CCW rotation (I never have been able to figgure that out)
As far a batteries go, I was planning on using 2 of the largest 6V hooked in series that will fit in the battery box.
mjbrown
06-26-2007 15:14:27
I had that done to mine a number of years ago ($350)and used a big 12V battery with big cables and starting it was marginal at best in the summer. I tried two 8V batteries in series for 16V and it worked better, fairly reliable in summer not good the rest of the year. Charging them was a problem. Finally I simply went to two 12V in series though fearing I would fry the starter. That was a couple years ago and so far so good. It gets the flywheel spinning real fast, real quick. Push the starter button and by the end of "one chipanzee" I can let up the decompression pedal. I'd rather spin it till I see oil pressure but I worry about the starter cooking. Mike Manley had a set up he swore by using 12V. Maybe there is still something in the arcives that far back. It didn't work well for me. Bottom line, I should have left the starter 24V and saved the money.
55 50
06-27-2007 09:22:12
 Re: 730 D 12V starter conversion in reply to mjbrown, 06-26-2007 15:14:27
Yes, your last statement really rings true! There are reasons that the John Deere engineers made it 24 volts in the first place?
buickanddeere
06-26-2007 12:07:39
The 24V frame isn't large enough. The 42MT core needs to be used and equipped with high torque windings. Going with the dual terminal unit is handy as the return path is no longer counting in the path through cast iron. And through several bolted surfaces to complete the circuit.
