Adding a Hand Lever to the Power Lift Foot Pedals
Loren in Iowa
06-26-2007 10:32:29
Picked up an adapter to add a hand lever to the old foot operated power lift, for an A. Thought I could just bolt on, and go, but found that the arm doesn't come out of the power lift at the right angle, for this to work. The hand lever would be way too far forward. Anybody know what to do? Can the shaft for the arm be pulled put, and rotated? Are these an aftermarket part? Don't see any JD logo, just the number C82, on the casting.
Lee B
06-26-2007 22:28:33
 Re: Adding a Hand Lever to the Power Lift Foot Pedals in reply to Loren in Iowa, 06-26-2007 10:32:29
My 44 "A" has both a baker lever on the left and a hand operated power lift lever on the RIGHT. Both work well and it's very nice. The power lift set up looks just the one on my 39 "B" except that one is entirely foot operated, the "A" can't be completely decked out with foot levers that way because of the battery box seat that is now in the way.
Don't know about the aftermarket status, casting numbers or history of even any mother Deere kits on the right side lever for that matter, I just always assumed it was a cobbled up add-on. Kinda like the battery box, as the only thing that looks factory there is the seat frame and back.
I&T manual seems to show that the internal parts on that shaft can be loosened and rotated about so that the external position could be any you need. I seem to remember tweaking mine a tad when I was in there years ago now.
Fredsjdb
06-26-2007 14:43:41
Loren, on my 46 B it came with a selective hand control lever. The part number for the kit is AA4268R. This is different then the normal levers on left side of the lift, this one fits on the right side and you have a long handle and a place to connect to the foot pedal. Hope this helps. There is a diagram in the B parts book on page 117. Good luck, Fred
Mike M
06-26-2007 10:38:33
I don't know what you are going to gain as it is still going to be set up for only up or only down so you may as well just tap the foot pedal.
JD did make a conversion kit so you could tap into those and run a single acting cyl. with a hand lever,but there was parts inside that need changed too. Most people just get the valve box unit from a later model with power-trol and it will bolt right on. Or you can get a Baker control valve off ebay and have the best of both.
