JD 430 carb trouble?
Steven Spickerm
06-26-2007 04:56:48
My 430 starts fine but once it's warmed up and under a load, it sputters like it's starved for fuel. Pulling the choke gets it back but only for a minute or two, then it sputters again. I've cleaned the line, float, and filter from tank to carb but haven't dug into the carb yet. It ran fine when I put it to bed last fall, problem began the first day I pulled it out this spring. Any thoughts.
CPeter
06-26-2007 06:08:29
 Re: JD 430 carb trouble? in reply to Steven Spickerman, 06-26-2007 04:56:48
Check the screen in the inlet elbow to the carb.
CPeter
CPeter
06-26-2007 11:40:37
 Re: JD 430 carb trouble? in reply to CPeter, 06-26-2007 06:08:29
Those screens are prone to drying out and the varnish in the gas clogs them up and reduces fuel flow. It often happens after a period of non use.
Do the flow test. Remove the plug in the bottom of the carb and you should get a continuous pencil sized flow for at least 30 seconds. If not. try at the fuel filter bowl with the gas line removed. There is a fine screen in the top of the filter, held in by the blow gasket. Also the outlet in the tank can collect junk and plug. Been there, done that.
CPeter
