Clutch Adjustments
sds46a
06-25-2007 23:42:09
I replaced the clutch linings and double sided disk(AD1027R) in my 52A. The replacement was thinner than the one I took out. I replaced the drive disk (clutch splines were built up/ground with weld). I now have a ear splitting racket when the clutch is not engaged and it quiets a little when engaged. Could the extra room from the thinner double disk cause the sliding drive disk to make the noise? Or is it noisy because I tried to repair the clutch splines without removing the crank?
Thanks,
Doug
Mike M
06-26-2007 04:40:08
 Re: Clutch Adjustments in reply to sds46a, 06-25-2007 23:42:09
If you are still getting noise with it engaged then you might have trouble with the tin dust cover not being centered,reduction gear bearings,or pulley going back too far and the gear is rubbing the main bearing housing.
sds46a
06-26-2007 22:38:00
 Re: Clutch Adjustments in reply to Mike M, 06-26-2007 04:40:08
Thanks Mike.
