Can you use a John Deere R for Bush Hogging?
Craig Ellis
06-25-2007 15:11:49
I never remembered to look, but does the John Deere R have a PTO to use a Bush Hog with?.... If not, what big John Deere"s out there do?.ie...The 830,730, etc.etc.
Thanks!!
DeereValley
06-29-2007 12:42:35
 Re: Can you use a John Deere R for Bush Hogging? in reply to Craig Ellis, 06-25-2007 15:11:49
I would not use the R because of the mentioned weak PTO. We have used 2 of our 80s and 1 of the 830s on a 15 foot Bush Hog. (One of the 80s has a brush shield my Grandpa built to protect the grille screen.) They pull well and use about half the fuel of the 4450.
Craig Ellis
06-26-2007 03:00:57
Thanks guys..... Yeah, I am wanting to get a John Deere R, ( I have fallen in love with them ), and it definetly would be used on the tractor pull, but was just curious on what I could do with it, meanwhile, while we were not at shows. We have 3 Fords, (860,861,8N) and we clean and paint them up when Flywheelers is comming, but we use them boys all the time doing bushhogging, box blading, etc.etc. They just dont sit in a shed for 3/4 time of the year. We just LOVE to get out there and use them in the field.
Thanks again
Mike M
06-25-2007 19:09:12
Sure you can ,but I'd caution against it as the R has a weak pto and the drive gears may be darn near impossible to find anymore and very hard to get at to replace. Any other model would be a better choice. If you go with a 730 you can also get a 3 pt hitch which the R and 820,830 won't have.
You could always get a 4010-4020 ?
pjbrown
06-25-2007 17:48:45
Did the R have 3 point hitch??
mjbrown
06-25-2007 18:33:26
 Re: Can you use a John Deere R for Bush Hogging? in reply to pjbrown, 06-25-2007 17:48:45
No. To bush hog with one you would have to have a trailable model bush hog.
bigblock
06-25-2007 16:58:54
I tried to bushhog with my 730,and it will do it but that hand clutch is a pain.Both feet and hand are busy all the time.Hope you have power steering.
Gary from Muleshoe
06-25-2007 19:33:00
 Re: Can you use a John Deere R for Bush Hogging? in reply to bigblock, 06-25-2007 16:58:54
We used a 630 to bush hog with all the time when I was a youngster. Never noticed any problems having a hand clutch. Why are both feet so busy???
The Dukester
06-25-2007 16:33:25
R's don't have the strongest PTO drive gearing so bush hogging isn't where they earned their fame, but they can do it. "Big Deeres" as you put it, were designed to be the power center of the farm or ranch where they were stationed. In their day they did it all as far as heavy work was concerned...every day, all day. Now days, most big Deeres have retired to show and/or pulling duties, but several are still out there earning their keep in the field, all seasons of the year....there's always something that a big John Deere two cylinder can do.
