730 crank end play
TomW
06-25-2007 07:46:48
I am back at the 730D again working to reduce end play in the crank. Thrust washers are new. The thrust plate looks worn. Is the a thickness spec. on this? I also saw someone mentions shims on a 720D to correct end play. Does the 730D use a similar shim? I"ve not seen them in any of me manuals but I have cheap manuals. Any help is greatly appreciated as the wife and I are both tired of my collection of none working machinary.
Thanks
mjbrown
06-25-2007 10:33:08
 Re: 730 crank end play in reply to TomW, 06-25-2007 07:46:48
Tom, I feel your pain. I finally resorted to drilling into the end of the crank and tapping it for a large fine thread bolt and made a plate from 1/4' steel with a clearance hole for the bolt in the center. I made a sleeve to fit over the crank cut to length to fit between the flywheel and the plate. Tightening the bolt into the hole in the crank end pushes the flywheel onto the crank and (more importantly) holds it there while you tighten it down. You can dial the end play right in and keep it untill the flywheel is tight. I only drilled into the crank end about an inch and a half. I can't see that the hole in the end of the crank hurts anything.
Mike M
06-25-2007 07:56:23
The 70D and real early 720D used shims to control end play the later 720 and 730 you just shove the fylwheel on farther. Did you replace the fiber thrust washer on the inside too ? 1 inside and 1 outside.
TomW
06-25-2007 09:07:26
 Re: 730 crank end play in reply to Mike M, 06-25-2007 07:56:23
Replaced both washers. My tractor is a 59 so it must just have the slide adjustment. The problem is I can't push in the flywheel far enough to get the play into spec.
Mike M
06-25-2007 10:03:29
 Re: 730 crank end play in reply to TomW, 06-25-2007 09:07:26
Do you have a taper-loc design or original type fylwheel ? The original type you really should have no problem drawing it up with that tin nut on the outside. A taper-loc can pose some problems getting it to stay where you want it as you tighten down cause the tapered collet moves as it tightens.
either one block the crank to the left at the belt pulley side and drive it on if it sticks.
TomW
06-25-2007 10:11:54
 Re: 730 crank end play in reply to Mike M, 06-25-2007 10:03:29
I have both types of flywheel. The standard won't stay for me. I can keep the taper-lock. Either way I have more play than I should.
stn.tn
06-25-2007 19:31:18
 Re: 730 crank end play in reply to TomW, 06-25-2007 10:11:54
if you use the taper-loc flywheel make sure you jam the pully end of the crank before tightening the flywheel to prevent damage to thrust.don`t jam the pully cover ,jam the crank end. also if you use the taper-loc tighten nut hit one side,tighten hit other,tighten,back and forth,along time ago i learned the hard way by not installing correctly.
buickanddeere
06-26-2007 12:02:22
 Re: 730 crank end play in reply to stn.tn, 06-25-2007 19:31:18
Isn't there a thrust washer that requires removing the main caps to replace?
Mike M
06-26-2007 13:19:41
 Re: 730 crank end play in reply to buickanddeere, 06-26-2007 12:02:22
Yep ! the inside one. He claims they replaced both of them ?
TomW
06-28-2007 04:18:48
 Re: 730 crank end play in reply to Mike M, 06-26-2007 13:19:41
Replaced both twice in 6 years. Crank just won't pull in enough.
buickanddeere
06-28-2007 12:14:23
 Re: 730 crank end play in reply to TomW, 06-28-2007 04:18:48
How far was the pulley driver pressed onto the crank?
