'' B'' carb bowl retainer ???
D.Will Greenwal
06-25-2007 07:27:59
I sold my "B' and now my neighbor needs help with his. Seems he removed the bowl and dropped what ever was in the tube that holds the bowl. now I don't have my info to help but I think under the spring is a ball . THis is the vertical tube that holds the bowl. Has a big brass nut on the bottom . Is'nt there a ball check up in there? IT manual shows nothing. Thanks guys. DAN
Mike M
06-25-2007 11:05:51
 Re: '' B'' carb bowl retainer ??? in reply to D.Will Greenwald, 06-25-2007 07:27:59
If he didn't allready break the stem off tell him to be very careful when he tightens it up. Use new gaskets and don't go too tight. That nut takes a large wrench but the stem won't handle all the torque it will apply.
D. Will Greenwald
06-25-2007 09:57:54
Thanks guys. I'll print this up and take it to him. DAN
F-I-T
06-25-2007 09:47:38
 Buy the part here..... in reply to D.Will Greenwald, 06-25-2007 07:27:59
third party image
BTW, you can see a diagram of the carb and get the spring from Robert's Carburetor. It's $2.84, but you'll probably want some gaskets as well.
Link
Frank
F-I-T
06-25-2007 09:49:02
 Sorry for the triple post. in reply to F-I-T, 06-25-2007 09:47:38
I kept getting an error that I had used a special character and that my message did not post. Guess the error message that it did not post was wrong.
F-I-T
06-25-2007 09:46:50
third party image
Frank
F-I-T
06-25-2007 09:46:07
third party image
Frank
John T
06-25-2007 09:04:02
Usually you cant get those nozzles to drop down n out unless you use a stick of dynamite lol. The spring which fits against the bottom center brass bowl nut is all that holds it up in the stem when all is new n clean. If it were out anyway I would clean it and all its lil side holes out, stick her back inside with the spring holding her up n have at it..... ..
John T
JD@Antique Acres
06-25-2007 07:43:32
Dan, What you will have inside the carb stem would be a nozzle which is held in by a spring. And which after you have the bowl on is all held together with the brass nut.
