50 carb problems
Jdman21
06-24-2007 16:05:25
I rebuilt the carb on my 50 and seems to run good, but the only way to start it is with the throtlle as low as it goes. Which is good. If I push the throttle ahead it will not start. it seems to idle good. But when I push the throttle ahead it dies. I can choke it to keep it running a little, but when I go to move the tractor it dies also. I can get it to move with a minute or two of choking and messing with the throttle, but I shouldnt have to do that. Once I get it to move it seems to run fine without any choking. Any ideas?
machinery-man
06-25-2007 04:44:38
 Re: 50 carb problems in reply to Jdman21, 06-24-2007 16:05:25
sounds like the accelerator holes on your main jet is still clogged and you're not getting enough fuel flow into the acceration well. You might compensate some with richer idle jet settings, however some of these tractors ran lean anyway...how does it run when warm. Try some seafoam in the fuel.
CENTAUR
06-24-2007 17:28:31
Can you open the idle mixure screw to give it the fuel it seems to be starving for.Open it up till you get the maxiumm RPMs.CENTAUR
