Deere 450 dozer
giuseppe
06-24-2007 09:56:36
I have a JD 450d dozer, I went to go use it the other day and discovered that the transmission is stuck between 2nd and 3rd... or perhaps stuck in third gears. I started it up figuring i could surely get it into a gear but the thing is stuck solid...and it is inoperable because after a little bit it stalls out. If anyone has any input or insight on the matter i would be extremely appreciative. thank you
Roy Suomi
06-24-2007 10:23:35
 Re: Deere 450 dozer in reply to giuseppe, 06-24-2007 09:56:36
You might need to remove the transmission top cover to see what happened to the shifter or forks..They come into the case from the side so you will be able to see most of the inner workings..You usually won't see 450 trannys stuck in gear due to the way they made the shifter pattern and followers..Under the top cover , the front half is the HLR clutchpack transmission..In the rear portion of the trans case is the gear change..
