4020 Repower
tom Hanson
06-24-2007 08:10:00
I've read a lot of discussion here regarding this, but little detail. I have a 66 JD 4020 gasser that is killing me in gas prices. The motor runs all right, but I suspect has a leak between the two center cylinders, a whole new story. I came across an engine out of a 7700 combine that is real reasonable in price and am looking at a transplant. I've read here that it should mate right up. Is there any frame stretching or serious other mods to do? Since this is just the motor, will the air cleaner, hyd pump, alt, etc. bolt up?
02XLT4X4
06-25-2007 07:02:53
 Re: 4020 Repower in reply to tom Hanson, 06-24-2007 08:10:00
I have seen one with a 4430 engine at a show, if it wasn"t for the bubble in the hood you wouldn"t notice it didn"t come that way. The owner really liked it, he initially bought it for salvage with a bad gas engine in it. The radiator was moved ahead and the hood was modified accordingly, it looked really good. If you have a good running gasser I am not sure if I would do it, but if you are staring down the barrel of a overhaul it would be worth checking into.
5020s rock
06-24-2007 15:02:06
hi--yes, that will work great. we did one years ago and its still going. we used 4320 side rails and stretched the hood. it depends if you have an early motor or late one with a turbo.
i have since learned you dont need the rails, guys
have used a different water pump or bent the fan blades or moved the radiator ahead to pick the 3 inch difference between the early model and late model.----if you dont buy the motor let me know
the number. thanks
chucky
06-24-2007 15:41:09
 Re: 4020 Repower in reply to 5020s rock, 06-24-2007 15:02:06
It isn't that bad of a swap, but certainly not a simple bolt up.
I have done it effectivly with out streaching the fram or hood.
A few thing that you will have to watch for is 1. you may have to notch the rear of the block on the left side for the return hydralic line to clear this can be done with a hand grinder.
2. You should be able to use the gassers flywheel but make sure that if the crankshaft on the combine is six bolt that the flywheel is six bolt or you will have to plug the two extra holes or crankcase oil will run out.
3. when using the gassers flywheel you will have to use the started head from the gasser and the starter from the deisel to match with the ringgear and have the power to spin the engine.
4. I personally moved the radiator ahead. You will only need to move it arround 1/2 an inch. Then I used the combines water pump and shimmed the fan out arround 1/2 and inch.
5. With the harmonic balancer/front pully I used on off of a 4320 and made clearance on the hydralic pump stands for this.
6. The hydralic pump drive coupler will also have to be shortened arround 1/2 inch and then you will have to tapper the splines on the coulper the match the splines on the shaft.
If memory surves me right the blocks are the same lenght but the lenght with the water pump is arround 7/8 of an inch longer.
Also check to see with engine the 7700 have in it. If it is the natually aspirered 4230 engine it should go as planed but if it is the turbocharged 4430 engine the you will have to deal with turbohood clearances also.
Good luck Chucky.
P.S. WTW, Dave Wickman from Cedar Rapids IA is very good with these converions.
ram ranch
06-24-2007 13:05:24
junk the gas, go 404 or 466. There is a reason they don't offer gas tractors anymore????? ?? Get it????
Gerald J.
06-24-2007 12:01:39
You might try adding some ignition advance and test with a timing light to be sure the centrifugal advance is working. A gas engine without good ignition advance is a gas hog. Not having additional advance for part throttle operation hurts economy too. That's a design defect of nearly all gas tractors.
With today's gas a bit higher octane than what was supplied in 1966 it may run with a bit leaner main mixture without pinging excessively and at the same time run more economically.
Unless you are running it hundreds of hours per year, I don't think an engine swap will ever pay. A few thousand for a diesel engine swap would have paid for a lot of off road gasoline without road taxes.
That engine in the 7700 is probably a 6404 and other than the displacement, I don't think it has a lot in common with the 4020 engines, so water pump and radiator plus most of the plumbing and fuel systems an intake plus exhaust would need custom routing (or running without a hood). But its not a swap I've tried.
I know the early 4020 gas engine like ours is closest to the 341 power unit used on the 65 combine, but shares no parts but a few bolts. Not even carburetors.
Not to say that our gas 4020s aren't hungry. I've worked mine over with a new float needle valve and seat. I've also made sure the Donaldson precleaner top is domed up instead of down. I have a clean dry air cleaner to keep air flow up. I have AC plugs with copper wires. I had to anchor the choke wire sheath near the carburetor to make it open the choke plate all the way. doing these things but my 4020's fuel consmption from 400 gallons a year to 250. Since then I've gone notill and do as much of that work as possible with my MF-135 that runs on a lot less fuel but won't do as much work per hour.
I now have to choke my gas 4020 for warm starts as well as cold starts. I think I have it leaned enough.
Gerald J.
msb
06-24-2007 18:52:07
 Re: 4020 Repower in reply to Gerald J., 06-24-2007 12:01:39
I am with Gerald on this.Keep it,do some updating like he says and add an electronic ignition or sell it or trade it for a diesel. You will have a misfit using a combine engine in my opinion and it will take a whole lot more fooling around and parts chasing to make a combine engine fit that most will tell you.The oil filter is an external one on a combine engine and should you want to sell it to a collector later in life, that alone would queer the deal.I hate cobbled up messes.
Geoff Mathews
06-24-2007 14:30:55
I am fascinated with this talk about gas tractors. Where I come from gas tractors were hardly ever known - the last spark ignition was MF 35 all fuel (TVO to us) in 1964. How did those big gas tractors shape up against the diesels?
Gerald J.
06-24-2007 18:04:44
 Re: 4020 Repower in reply to Geoff Mathews, 06-24-2007 14:30:55
I think the gas engines pull as well and though a gas engine is known to need tuning more often, I've been doing it for more than a half century and I know how. You can do a hole passel of plugs, points, condensors, and float needle valves for the price of one set of injectors and one injection pump rebuild.
True, all the known big gas engines (and 341 or 360 cubic inches isn't all that big) deserve their reputation as gas hogs, but regular tuning can help that some. When mine first arrived it smoked like an IH diesel puffing a truly large black cloud when goosed after it had been idling for a few minutes. Today I idled it for half an hour with no smoke before, during, or after. I've weaned mine quite a bit.
A fundamental failing in almost all gas tractors is that lack of vacuum advance for part throttle operation. I converted a Pinto wagon over to a purely centrifugal advance once and while it ran great at full throttle it was a dog a part trottle and didn't have its normal fuel economy. The factory distributor did better and as soon as I could get one I went back to the factory distributor.
A gas engine can be tuned to run on ethanol, or ethane, or natural gas, and propane was a factory option. When I made my gas/diesel decision I factored those in and biodiesel was not even a gleam in the eyes of inventors.
There is enough difference in fuel efficiency that the water pump and radiator are larger for a gas tractor compared to a diesel tractor.
When I bought my gas 4020, the premium for a diesel was about $4000. I figured if I burned 400 gallons a year that would fuel it for 14 years, not just pay for the excess fuel cost of gasoline. Since then fuel prices, both gasoline and diesel, have risen and I've weaned my 4020 back to 250 gallons a year with full tillage and now that I've gone no till, my fuel consumption is a lot smaller.
Most diesels seem to need warming to start in very cold weather, while a gas will start if it will turn over at all, in my experience. When planning winter operation that can be a factor, I think, in favor of the gas tractor.
Were I using a tractor 500 hours a year, I'm sure the economy of a modern diesel would pay, but in my operation, the gas 4020 is a good fit.
Gerald J.
Nylon
06-24-2007 22:35:17
 Re: 4020 Repower in reply to Gerald J., 06-24-2007 18:04:44
I have a diesel 4020 and I live in a northern MN. I use it mostly as a loader backblade and snowblower type tractor. In a cold climate and with alot of idleing I would actually be better off with a gas version. Starting would be less of an issue. Also idleing so much. Just my opinion. We have a IH 460 gas that gets used alot but no cab for winter. Plus, if you add up the price differential between gas and diesel, I doubt it would ever add up to the total price, headeaches, and the hybrid in the end.
