JD A Clutch Adjustment
Joe Appelget
06-24-2007 08:05:41
Hello everyone!!
I am having clutch problems on my 1946 JD A. It wouldn"t disengage, so I took it apart and found the clutch discs (free facings) totally fried. It also had 3 broken clutch dogs, so I replaced those. now the clutch engages and disengages, almost. When dinengaged it still grabs slightly and you can pull back on the clutch handle and stop the pulley with the pulley brake, however this produces the smell of a burning clutch and slight smoke out of the clutch, as the cover is currently off. The tractor does not move at all when it is shifted into gear and the clutch is engaged. The fork braring is very worn and the fork shaft and the fork bearing have been welded together also. I have a feeling that everything is too worn for proper opperation, but I need to move the tractor enough to load it. any suggestions on clutch adjustment?
Thanks,
Joe
Sam in MN.
06-25-2007 18:38:52
 Re: JD A Clutch Adjustment in reply to Joe Appelget, 06-24-2007 08:05:41
Joe,
I have a 48A and it took a couple tries to get the fork in the slot on the back side. Looks like it is sliding into the slot and the last second it wants to slip behind the fork slot.
That would be the first place I would start and it is only a couple bolts to check it out.
Good luck,
Sam
