Front axle downtube on 4020
Nylon
06-23-2007 20:18:57
Noticed this a while back but tried to see what trouble is with downtube and control arm. When I down pressure the loader enough to lift wheels off ground the front right control arm drops down. I took the cap screw off the control arm thinking it wasn't down on the splines all the way. Tapped up the control arm and the splines come all the way up and meet flush with the top. So tightening down the cap screw any further can not be done. Wheels back down on the ground and the right control arm lifts up again. The distance between axle crossmemeber is 1/4 more on the right side. So thhinking something on or in the bottom of axle downtube is missing. Axle downtubes measure out to be same length.
No I don't have a parts book yet. Have operators manual and IT for it but no parts book. Working on that. Plus can not seem to negotiate my way around jd parts web. Anyone know what probably dropped out of there and didnt get replaced?
Wondering too what a technical manual covers....whats the diff between manuals?
Thanks,
John
Gerald J.
06-24-2007 09:23:59
 Re: Front axle downtube on 4020 in reply to Nylon, 06-23-2007 20:18:57
The Deere shop manuals are THOROUGH and mostly correct. The I&T manual covers some details, not necessarily with the same detail as the Deere Manuals.
There are two different shop manuals for the 4020, depending on serial number. The wrong one will lead you astray in many details. SM2039 fits the pre side console 4020 as I recall. You have to be sure about the sn covered by any parts book too.
My parts book shows two thrust washers at the bottom of the KNEE and two bushings, one at the top and one at the bottom. I think there has been a difference in the length of the spindle, and a long spindle for the few high crops made.
It might be possible to push the steering arm on further by making a washer to fit outside the spline but still under the original top washer.
Gerald J.
Shoes
06-23-2007 21:20:02
Your thrust washers are probably missing. Check your extension and spindle for wear. If it hasn't been used to long this way, you can possibly just replace the washers and roll pin.
Nylon
06-24-2007 11:07:48
 Re: Front axle downtube on 4020 in reply to Shoes, 06-23-2007 21:20:02
Thanks for the info.
If I raise the axle and pop off the steering arm from the spline spindle, can I tap down the spindle enough to see if those thrust washers are there? There are some dowl pins shown in my IT manual but really doesnt explain or show exactly where those dowl pins go or what they hold/ pin into. Since there are supposed to be 2 thrust washers...probably 1/8" per would explain the 1/4" height difference.
