Batteries for 630
EHinSC
06-23-2007 14:13:01
Did this tractor originally have two 6 volt batteries? Mine came with one 12 volt and it keeps draining down, suspect it is shot. Manual says Goup 1 battery, but all new batteries are sold by cold cranking ratings. What is the best battery by brand and size that I should look for, and should I look to put a cut-out on the positive side? Thanks for any help!
Ed
EHinSC
06-24-2007 10:34:28
 Re: Batteries for 630 in reply to EHinSC, 06-23-2007 14:13:01
Thanks to all for the replies! To all you experienced two-cylinder owners, it probably was a really elementary question! Thanks again!
Ed
Pete in MD
06-23-2007 21:16:35
A quick cut-off is a good idea. I'd put it on the grounded battery post, no matter whether you hook up the battery pos or neg grounded.
buickanddeere
06-23-2007 18:52:39
Link
Use the highest CCA vibration resistant battery that will fit in the box.
Carl NY
06-23-2007 15:35:46
Ed- I replace the two 6 volts with one 12 volt. Usually a 1000 cold cranking amp type. Battery technology has improved from when these tractors were producced. Around here 6 volt batteries usually spend half their life cycle setting on the shelves waiting to be sold. Remember to hook it up positive ground.
