4020 vs 3020
Nylon
06-22-2007 21:44:44
Why was the 4020 considered to be that much of a better tractor over a 3020? Because it is relativly nimble even with the extra hp over a 3020? Just curious.
zwr
06-23-2007 21:45:38
 Re: 4020 vs 3020 in reply to Nylon, 06-22-2007 21:44:44
The only concern I would have about the 3020 is the four banger engine with the internal countershaft to cancel the vibration inherent in the four. Something else to break. But even there, in its day it was head n shoulders above most of the competition, which didn't bother with a balancer. I owned a "large" four cylinder MF that performed well except that nobody wanted to operate it. The vibration alone would wear you out.
Compared to others, both the later 3020 and 4020 with the side hydraulic console were "dream machines" to operate.
JD steve
06-23-2007 10:18:53
the 3020 is for mowing and 4020 is for field work
buickanddeere
06-23-2007 06:23:30
A 3020 is 2/3 of a 4020. They do have an internal balancer than can get $$$ that a 4020 doesn't have. To operate any tractor or equipmen of that age you have to be a fixer or have a volume discount with your local fix-it shop. 35-40 years of aging and wear takes it's toll on every component.
Mike M
06-23-2007 03:50:28
I think one is really just as good built as the other. But I hate the sound of that 4 cyl. !!!!
A 4020 isn't that much larger and can get around pretty well in tight spots. Different tire and frt ends can help too.
dds-inc
06-22-2007 21:48:01
eh? A 4020 is one size larger than a 3020. A 4020 has 6 cylinders and a 3020 has 4. There is no comparison. A 4020 will boss a 3020 around.
Nylon
06-22-2007 22:08:06
 Re: 4020 vs 3020 in reply to dds-inc, 06-22-2007 21:48:01
I guess what I meant was that other than the proportional size difference, was / is the reliability and its usefulness similar? Or, feature wise and reliability were they apples and oranges?
Gerald J.
06-23-2007 15:35:58
 Re: 4020 vs 3020 in reply to Nylon, 06-22-2007 22:08:06
They do share some parts like three point and pistons, sleeves, and piston rods, plus main and rod bearings. Seats, steering parts.
Gerald J.
dds-inc
06-22-2007 23:12:41
Sure, they're just as reliable. As for capabilities, you wouldn't use the daylights out of a 3020 to pull something that goes behind a 4020 unless you're really hard-headed. There goes your reliability and durability for the 3020.
