1951 Model A Brakes
rhryan
06-21-2007 17:57:47
Both brake assemblies have an oiler and my operator's manual indicates that lubrication is required every 500 hours. However, the manual does not state what the lubricant should be used. I disassemblied the right brake unit because it was frozen. I noted the passage for the oiler leads to bushing cavity. What is the purpose of the oiler for the brake assembly?
F-I-T
06-21-2007 18:50:35
 Re: 1951 Model A Brakes in reply to rhryan, 06-21-2007 17:57:47
The bushing is porous, and the material is called Oilite, so the oil that comes down from the oiler "weeps" through the bushing wall to lube the shaft. Engine oil works fine. Just a few drops.
Frank
rhryan
06-24-2007 12:04:56
 Re: 1951 Model A Brakes in reply to F-I-T, 06-21-2007 18:50:35
Thanks, Frank.
I have another related question to the brakes that I hope you could help me with. When I removed the nut from the brake shaft I noticed it was not tight (previously diassemblied probably). Unfortunately during reassembly I realized I did not have brake shaft thrust washer 24H77R. I assume that the washer butts up against the shoulder inside the housing and end of the pinion gear A1162R. The parts manual is not not exactly to scale regarding the washer or at least for me it is not. If I am correct the washer should be able to fit inside the bore of bushing A1166R. Am I on the right track and how critical is the washer?
Thanks, Raymond
F-I-T
06-24-2007 16:36:29
 Re: 1951 Model A Brakes in reply to rhryan, 06-24-2007 12:04:56
It has been a long time since I had a riveted drum type brake apart, but as I recall, the washer goes over the pinion gear, and it protects the teeth from gouging the end of the housing and the bushing after you set the endplay to .020" or so (I can't remmeber that number without digging into a book that I can't lay my hands on right now). If you look at other parts manuals, the ones with the integral gear and shaft (50/60/70), you'll see that they machined a shoulder there to provide the spacing, but on yours they used the washer instead. I would say it is very important.
Frank
