three point hydraulic lift
Benoit Chouinar
06-21-2007 13:14:52
I use my 1958 420U to haul firewood. The three point hydraulic doesn'nt work anymore. I've took some actions:
1 Check the oil level. It's full
2 Check the hydraulic pump. It had some wear so I rebuilt it.
3 Check all the oil pipes for leaking. No leak
I lift by hands the three point attachment. It's quite easy to lift up, and it's falling down when I put my hands off.
What can I do with that ?
Dave H
06-21-2007 17:13:10
 Re: three point hydraulic lift in reply to Benoit Chouinard, 06-21-2007 13:14:52
Benoit
that easy lift by hand and drop down is fine. It means yur piston/pistons are in the down position. I am talking 58 420 W and the rods are not connected to the pistons via a pin, so you can always lift the arms up when they are down, by hand that is.
If you rebuilt the pump and put some assembly lube in it it should have self primed and sucked and pumped. A lot of times there is a priblem with the juncetions on the large return line to the pump letting the pump suck in air. All the bushings/seals should still be availabel for it.
Wayne would say to crack the pressure line loose where it feeds into the tom and if the oil squirts out there and all over your shoes, the prob is then inside the tom unit. I would try Wayne's tick first and post back.
