FIT re 720D
Fredsjdb
06-21-2007 09:04:21
Hi Frank, I"m helping a friend with an early 720D that he recently purchased. He hasn"t received his manuals yet. We discovered the flywheel is cracked and it is a later model flywheel(F3570R). I have looked at previous posts and read there are differences in the drive gear and main bearing housing between the early and later models. Can you provide any of the part numbers differentiating between these so we can order the proper flywheel? Thanks, Fred
Blksmok
06-21-2007 12:25:49
 Re: FIT re 720D in reply to Fredsjdb, 06-21-2007 09:04:21
Fred...forgot to mention. When you pull the flywheel, inspect the splines of the crankshaft closely for wear. The current flywheel may have cracked because they couldn't keep it tight on the crankshaft, so they got a bigger lever and over-tightened it..causing the crack. A new flywheel will not work if the crankshaft splines are worn. If they're worn...time for a Taper-Lok flwheel or a new crankshaft.
Mike M
06-21-2007 11:14:56
I think you will find the flywheel difference boils down to if your flywheel needs the pin to drive the slinger or not. Aftermarket taper lock ones come with a sq. headed setscrew you can put in or take out as needed. You can always pull the drive pin out of an original with vise grips or if you need one drill a hole and put one in.
Mismatched parts in those for the slinger and thrust washers seems to be the norm from the ones I have worked on. I take it all out clean it all up and get the parts book out and sort it out.Even a veteran parts person can get confused on those so take your time and double check all the parts and part numbers.
Fredsjdb
06-21-2007 11:05:51
Thanks for the fast responses, it is an early 720D and should have the F1913R flywheel. I'm going help take the flywheel off tomorrow or saturday and then we can get a better idea if there is a bunch of mis matched parts. Frank, I'll try to e-mail you later when your not traveling or busy. Thanks again for help. Fred
Blksmok
06-21-2007 11:58:37
 Re: FIT re 720D in reply to Fredsjdb, 06-21-2007 11:05:51
Fred....Mike M is right. You'll probably find a mixture of parts when you pull the flywheel and thrust cover (oil slinger) off. The F1913R flywheel should have a F1928R thrust cover,a flywheel spacer (A3324R), two fiber thrust washers and a metal thrust plate. The F3570R flywheel should have a different thrust cover,a F3565R spacer, one fiber thrust washer and no metal thrust plate. Happy hunting!
F-I-T
06-21-2007 11:27:28
Fred:
I think Blksmok has you covered, but feel free to e-mail me anytime. When I have a chance to review a parts book I'll be smarter. Without a book I'd just be guessing.
Blksmok
06-21-2007 10:45:40
Fred....if your friend's JD720D has a serial number greater than 7214900 (black dash models) the F3570R flywheel is the correct one. The earlier JD720D and 70D's used a F1913R flywheel. There are quite a few part changes after 7214900, but if the 720D had the F3570R flywheel and the it's a black dash model, the other internal parts should already be correct. The thrust cover and flywheel spacer are different depending on which flywheel you're using.
F-I-T
06-21-2007 09:20:57
Fred:
Normlly I could, but I had a hard drive crash on Tuesday on my main laptop, and my back up files are at home. If you don't get any help here, e-mail me directly: [email protected] and I'll get the info for you this weekend. I fly all day Saturday, but I should be able to get what you need on Sunday.
Frank
