466 safe rpm
weeze
06-20-2007 19:55:20
i just bought a 4010 with a 466 stock engine . our class rules allow 4000 rpms will a stock engine be reliable ? need to know before i buy the injector pump. thanks
buickanddeere
06-21-2007 06:05:30
 Re: 466 safe rpm in reply to weeze, 06-20-2007 19:55:20
Is the engine balanced and blueprinted? What cam profile and valve springs are in it? Float those valves and whack on with a piston? You are now looking at a brand new boat anchor. A diesel in particular has very little valve to piston clearance at the best of times. If it's really stock then peak HP will be in the 1400-1500 rpm range. And peak HP will be in the 1800 to 2100 rpm area. 4000 rpm is a long way from there.
95CS
06-21-2007 05:01:06
You might be better off asking your question on the Pulling Forum.
