Folks Say You Guys Can Help With JD 50 Wiring Issues
Cricket
06-20-2007 09:38:54
Hi - I've been begging for info on several other (non-tractor related) forums, and a number of people have sent me here. They claim you know all... ;>)
Anyway, my late husband, Mr. Who-Me-Do Maintenance?, left me with a late forties (he said) JD 50 that ran, sort of. Over time, various fasteners have shaken loose (Check them? Why?)
Usually not an issue, except - two wires on the back of the voltage regulator, one black, one white - right or left? He had taped the top back on the VR, when I pulled the tape I did not know that that was all that was holding those two wires (or their screws) in place. Bummer.
So now I have two wires that I don't have the guts to guess at, all that's keeping me from trouble-shooting the ignition switch, which has it's own troubles but at least has no mystery wires...anyone either know the answer, or where I can get a wiring diagram sometime soon that won't cost an arm and a leg (that old tractor is pretty much par for what he left me - can't afford any high-dollar books just now...)
You will have my eternal gratitude, plus I'm almost certain to come back and ask amusing questions...I did the plumbing, John did the wiring, so my grasp on electronics is a tad...tenuous... :>D
Thanks...
John Van Valkenburgh
06-22-2007 20:05:16
 Re: Folks Say You Guys Can Help With JD 50 Wiring Issues in reply to Cricket, 06-20-2007 09:38:54
third party image
Cricket,
I've attached the schematic for the 50 from the original John Deere Owners manual. The wiring is really pretty simple on the 50. Originally it was 12 Volts, Positive ground. What this means is that the "+" battery terminal was grounded to the tractor frame and the "-" battery terminal supplies the current to the starter etc. This was not unusual in the 1950's but is not commonly seen these days. Some people have converted their tractor over to "Negative" ground. Just look at the battery connections and see which terminal is connected to the frame.
Parts for the 50 are not hard to find but most of the time you have to order them. The 50 originally came with a 12 Volt Generator with the Voltage Regulator (little square box) mounted on top. The Voltage Regulator will have either 3 or 4 terminals depending on the type. Some people replace the generator with a more modern alternator for faster charging, but I've found that the generator on my 50 works well.
As "Ten-Twenty" mentioned the model 50 was actually made from 1952-1956. It was quite a tractor in it's day, and while there are more powerful machines available today, the 50 is still a great little machine with plenty of power for most small farms.
Most model 50's were the tricycle style with two front wheels mounted closely togeter. Most 50's had a "live" PTO or Power-Take-Off for running things like bushogs etc. Most 50's also sported a live hydraulic lift system. 3 point lift hitches were available but not common for the 50, but you can get nice aftermarket 3 point hitches for it today.
Some later 50's even came with power steering, although the steering is pretty easy once the tractor is moving.
On the right hand side of the tractor, next to the big pulley you should find the tractor's Serial Number plate riveted to the frame. You can look up the tractor's year from the serial number on this site. There were a few improvements made over the production years and so knowing the serial number is handy.
Drop me an email and I'll talk you though anything I can. I don't blame you for not wanting to work on the tractor after shoeing horses. After the 3rd shoe my back is giving out and my Quarter Horse is getting impatient.
John
1953 Model 50
Cricket
06-23-2007 05:08:00
 Re: Folks Say You Guys Can Help With JD 50 Wiring Issues in reply to John Van Valkenburgh, 06-22-2007 20:05:16
Thanks! Now I've got several slightyly different versions (not in details, just in views), which is always good.
The wiring on the ignition switch is all faded to cream colored, so that's going to be done ver-r-r-y carefully...no color codes to follow at that end!
It's still 12 volt positive ground. It has a three point hitch and live PTO, and John had just re-done most of the hydraulics, so that's one issue dealt with.
It's in fairly desperate need of a ring job, and the brakes are so far out of adjustment it's pathetic (John with his three foot long legs just figured "Stand up on 'em!"...I'm 5'1"...).
Oh, and first thing I did was unstick the "short lever" (seat adjustment)!
I'm off for a week of backpacking with my kid and my sister, now I can't wait to get after the thing when I get back - thanks again to all who replied!
Cricket
buickanddeere
06-23-2007 06:41:37
 Re: Folks Say You Guys Can Help With JD 50 Wiring Issues in reply to Cricket, 06-23-2007 05:08:00
The brake adjusters should be getting a spray with PB Blaster a couple of times a day for a week of more. You may be fortunate and be able to dial them back into service. On the regulator and generator. The F & A terminals on the regulator go to the F & A on the generator. The wire coming from one side of the amp meter should run up to the L or B terminal on the regulator. The wire on the other side of the ammeter should disapear down towards the starter. Depending on the serial number. The early 50's had a modest 12A gen without a fan. The later 50's were equiped with a more vigerous 20amp gan with a fan. In either case the regulator's small ajustment screw closest to you may require calibration. Fortunately a decent analog volt/ohm/amp meter is 10-15 bucks. Make certain the dial settings are for DC volts and the wires are plugged into the common and voltage. With the battery full charged.The regulator should be set for 13.8V with the lights on and the engine at full revs. If your tractor has the fan equiped generator then you can use the 1195 or 795X lamps in the headlights and taillight work lamp. Sometimes a smoking engine just needs a change of oil & filter. Also the aircleaner bowl and perhapes the metal mesh hidding above it likely need cleaned out too. Then work the engine hard for several hours and find the proper carb adjustment. I'm somewhat partial to the 50 & 520 myself. A perky little performer in a numble package. I raked a lot of hay as a kid on those.
Ten-Twenty
06-20-2007 13:34:49
Cricket,
Assuming your tractor is a Model 50 (manufactured from 1952-1956) and it still has a generator and everything is still wired as it was from the factory, the black wire should be connected to the terminal marked "L" (the terminal on the right -front of the tractor- as you are facing the generator/voltage regulator. The white wire should be connected to the center terminal, marked "B".
Good luck with your wiring repair and ask further questions if you need to.
Cricket
06-20-2007 16:52:58
 Re: Folks Say You Guys Can Help With JD 50 Wiring Issues in reply to Ten-Twenty, 06-20-2007 13:34:49
Oh, thank you thank you thank you - that was what I was 90% sure of (due to the bends in the wire), but not completely (and neither is marked anything, as rust has set in...).
Eventually I need to come up with a wiring diagram, but so far that's the only thing that is actually disconnected without an observable "other end".
I thought John said late 40s, but could have been the JD his Dad had when they were kids that he was talking about.
Anyway, tomorrow will hook it back up and see how it goes - been shoeing horses all day and I feel like I've been drug through a knot hole.
