All fuel 70 hp
New 70 on the b
06-20-2007 07:17:38
63 hp, 2 barrel carb, stock stroke. Lugs and holds 85 below 540. Whats a 70 stock in HP? New70
easydoesit
06-21-2007 08:06:46
 Re: All fuel 70 hp in reply to New 70 on the block, 06-20-2007 07:17:38
I"m glad New 70 is feeling good about his new toy. Give him a break. I just got an AF 70 and putting 125 over Alum pistons in it. What kind of HP will I expect? I never had anything more than a std. JDG before....Easy
buickanddeere
06-21-2007 10:27:36
 Re: All fuel 70 hp in reply to easydoesit, 06-21-2007 08:06:46
What compression ratio? If stock AF, HP will still be stock or maybe 1 HP more at most. What is the current bore size and condition?Are you going to resurface the cam followers and grind the camshaft? If the bore will cleanup at 45 or 90 over. There is no need or gain going 125 over. Are you planning on doing some port matching, valve bowl work, relieving the eyebrows and doing a multi angle valve job? The kid failed both math and physics class.
easydoesit
06-21-2007 13:20:06
 Re: All fuel 70 hp in reply to buickanddeere, 06-21-2007 10:27:36
Stock compression. No fancy valve or cam work. The cylinders are pitted at 90 over and I have some G sleeves if it won't clean up for 125. I have gas stock, 45 & 90 over pistons now. Which is better? Easy
F-I-T
06-20-2007 08:05:44
How much below 540 rpm? If you lug it below 540, which is the rated speed, the dynamometer might show more pressure (translated to lifting pounds of weight), but you're achieving it at a lower speed, which is fewer pounds of lift per hour, which means less horse power, since that is an measurement of torque over time. You have to correct that number to standardize it at 540. For example, if you lug it down to where you are getting 100 hp at 270 rpm, you really are doing the same amount of lifting (twice as much at half as fast) as you would lifting half the weight for twice the time at 540 rpm.
Stock 70 A/F got right 45 hp on the belt, which is a close translation to its pto output. Yours appears to be spunky. Gas pistons?
Frank
New70
06-20-2007 15:47:18
 Re: All fuel 70 hp in reply to F-I-T, 06-20-2007 08:05:44
400 pto rpm. M&W 100 hp dyno @ 540, 150hp @ 1000 intermediate. It will probably lug harder, but its still pretty "New" but it sounds really good. Wish the dyno had the paper work or a straight out pressure guage. 70
F-I-T
06-20-2007 16:27:42
 Re: All fuel 70 hp in reply to New70, 06-20-2007 15:47:18
I don't follow the M&W 100 hp/150 @ 1,000 rpm. I thought they all had directl reading gauges. If not, what are you reading? I have a M&W P400 that has the pressure gauge with the hp scale alongside, and you can read the conversion directly if you are at the rated speed.
Otherwise you have to do this:
63 @ 540 and 85 @ 400?
400/540= .74
.74* 85 = 63
So your 70 makes 63hp @540 = 85 @400 per your results.
Frank
New70
06-21-2007 08:09:53
 Re: All fuel 70 hp in reply to F-I-T, 06-20-2007 16:27:42
Right. Before hand it was 42 @ 540 and if you made it to 70 at 400 before the needle dropped off and the engine started to sputter, you were lucky. Needless to say, before hand, it would have never been able to handle the load it is capable of handling now. Either way, its considered a torque increase due to the higher pressure readings on the guage. My guage is primative, older dyno. Just HP in 2 range readings, one range for 540 one range for 1000 or direct drive. No other numbers or readings available for this guage.
F-I-T
06-21-2007 11:17:45
 Re: All fuel 70 hp in reply to New70, 06-21-2007 08:09:53
But it's not a torque over time increase. You have more power now, but I was trying to explain that the 85hp you got for 400 revolutions in a minute is the same as you did turning it 63 hp for 540 revolutions in a minute, so your 85hp is 63 hp corrected to rated speed. You don't need an extra dial to tell you that. Just read your hp at the rated speed. If you're wanting to plot a torque curve, so far you've shown it to be flat, no slope, between your two points, not? You have to recorrect the horsepower at each point back to rated speed to get such a graph. Otherwise, I guess I'm not following. The farther you load it down, the more pressure you will see until the becomes asymptotic up the vertical axis. The torque will go up forever as the rpm's fall to 1,000, 500, 250, 125, .0001, that is if the engine could stay running.
My gauge only has two scales: 540 standard and 1,000 rpm. If you are turning the shaft at 540, read that scale. It's just converting the psi per rev into the torque/time = hp formula. You have all the information from your dial to compute it. What you're looking for is say you loaded the engine down so as to cut the shaft speed by 50%. Now, if the hp reads as greater than the 50% of the rated speed number, then the engine is developing more effective torque/time per revolution at that speed. You can cipher the rest out. The pressure reading is twisting force epressed as psi on your gauge, this is true. But horsepower is that torque over time. If you can gear everything down far enough you can get 5,000 foot pounds of torque, but the shaft would be creeping along.
Sorry if I'm not following you on this. I'm pretty slow sometimes. Maybe someone can help me out.
buickanddeere
06-20-2007 09:13:54
35% torque rise, not bad. I wonder where this "HP gain" while below rated rpms belief comes from.
torque X rpm / 5252 = HP is a well known formula.
New70
06-20-2007 15:54:32
 Re: All fuel 70 hp in reply to buickanddeere, 06-20-2007 09:13:54
From that big guage on the dyno! When the entire neighborhood hears that 70 spout off a song and pull on the wheel a little bit more, it makes the ground shake a little.
buickanddeere
06-20-2007 20:41:08
 Re: All fuel 70 hp in reply to New70, 06-20-2007 15:54:32
Your are forgetting or don't know that " lb ft torque X rpm / 5252 = HP"
New70
06-21-2007 08:18:40
 Re: All fuel 70 hp in reply to buickanddeere, 06-20-2007 20:41:08
So, how does one solve for "X"? X = torque or ftlbs. can your equasion be reversed to find the torque and then re run your formula to be more precise? Now if one was dynoing a plain jane farm tractor, most consider the 540 rated rpm to be thats it and there should be no more needed to test. Right? (thats my opinion) But say a puller, that throws the monkey wrench into the machine in how the method is done when looking for tune. In a perfect world, or engine, the motor should not ever ever drop below rated rpm. (once again, just my opinion) But, the engine, 9 times out of 10 does drop below rated rpm. whether it be by drivers throttle position, or its putting such a load on the motor, the governor will hold the carb open all the way and its running at its full potential. Now if it was running all the time at 540, Id agree, then all that needs to be checked is the 540 reading. But we dont! We check the low end torque by measuring the baseline we first test, then measure it again at the same speed. Higher the number, or pressure, than what it was before, shows torque increase.
AW Puller
06-21-2007 11:04:39
 Re: All fuel 70 hp in reply to New70, 06-21-2007 08:18:40
Chad, Chad, Chad.....I thought we have been over this and you finally got it thru your head how algebra and physics work....obviously not. How many times does someone have to tell you how horsepower, RPM and torque are mathematically related?? When you pull the engine down with the dyno and the guage shows increased pressure, that means torque is rising...BUT!!! the pressure may be going up, but if the RPM is dropping, there is no horsepower increase!
150HP on a stock stroke 70, lmao! If you stood near the thing @ 1000PTO speed, you have bigger balls than I do. But after hearing your tall tale of the 200someodd HP bone stock 460 engine at lord knows how many RPM, I can believe it coming from your mouth.
New70
06-21-2007 17:54:25
 Re: All fuel 70 hp in reply to AW Puller, 06-21-2007 11:04:39
No, I said it could be a 200 hp Ih 6 cyl. RPM, to be announced. Nobody said anything about a 150 stock stroke 70, that was the ranges and limits of the dyno to give a description on the dyno. it a 3XX model M&W dyno. 3 guages on it, pretty simple. Id have to hear more on what you mean by all things being related mathmaticly. But, 63 hp out of a stock stroke 70 all fuel with John Deere pistons, and run on pump gas I thought would grab your attention. So, 63 at 540, lets leave it a that,,, unless youd like to be more specfic, and with respect in saying this, Ill show you how I did it, and what it can do, if you want to tell me how it works. But on what im describing, its the difference in the readings noted on the guages from engine to engine combo. A 540 reading is a reading, a reading taken at 400 pto is a reading, compare the two engine results and the difference is clear. What it is is not important, its how much the gain is is whats important to me. It was 42@540, and 68 at 400 the second was 63, and the 400 was 85.
F-I-T
06-21-2007 18:59:09
 Re: All fuel 70 hp in reply to New70, 06-21-2007 17:54:25
and it'll be 126 at 270, AND IT'LL BE 170 AT 200 PTO RPM! (If the engine does not stall. That's what we're trying to get you to understand. 63 hp out of a 70, if it has all-fuel compression is real good, with gas pistons, real nice, that's all. But you're not the first guy to get 720 type output out of a 70 engine....
buickanddeere
06-21-2007 10:53:46
The formula like any other can be re-arranged to find the one unknown when the other two variables and the constant is known. The governor is a simple proportional unit that senses droop and opens the throttle to compensate. There is approximately 10% rpm loss before the governor will move to 100%. Too bad An Integer function isn�t incorporated but that would be more $$$ to build and service. This is why rated/peak HP is taken at 975 rpm and rated fast idle is 1075 rpms or so if memory serves correctly. Peak HP rpms are where the engine pumps the most air per minute through it. Peak torque on the other hand occurs at the rpm where the engine is breathing a max volumetric efficiency. This is where the engine pumps the most airflow per stroke. If the carb isn't being held wide open after the throttle is pushed fully ahead and the pto at 540 rpm when full loaded by the dyno. The throttle & governor is not setup properly. If you are spinning the dyno at 400rpm instead of 540 rpm. The your HP readings have to be multiplied by 0.7407 When was the last time the dyno and rpm meter was calibrated? The numbers just don�t jive.
You are getting 85HP at any rpms from a stock stroke 70AF. There is more than what meets the eye here.
New 70
06-21-2007 18:08:02
 Re: All fuel 70 hp in reply to buickanddeere, 06-21-2007 10:53:46
Not any rpm,, just at 400 pto rpm, 375 and its on its way down fast, but it stays steady and holds the needle there at 85 at 400. The throttle is wide open. The tractor is 63 hp at 540. With a stock crank, and John Deere pistons used. Thats dyno tuned with the jets set and the timing set on the dyno. So 63 hp is all thats important.
buickanddeere
06-21-2007 19:56:06
 Re: All fuel 70 hp in reply to New 70, 06-21-2007 18:08:02
The numbers just don't "add up". Replacing a set of stock AF pistons in a 70 and replacing them with another set of AF pistons. That isn't going to raise HP from 45 to 63. That is 1.4 times more HP. Gasser was 50.35HP, LP was 52HP and diesel 51.5HP. Even going from the AF ratio of 4.6 to 1. To the gasser 6.15 to 1 won't increase HP that much. Even going to the LP ratio of 7.3 to 1 as the only modification is stretch to make 63HP. The G and 70AF engines share the same displacement of 413 cu" vs. 379 cu" for gassers. Even if your AF was making the LP tractor's HP per cubic inch. That's still only 56.66HP. If your AF has 8 or 9 to 1 pistons, is port matched, bowl polished, multi angle valve job, casting flash removed. A cam from Roberts and a dry air filter conversion. Then sure 63HP at 540 pto rpms is easy, 70HP possible and if well tuned. Maybe even a few more HP. In short there is absolutly no way on earth your 70AF is making 63HP at 540 pto rpm with just a set of 45,90 or 125 over gasoline pistons as the only modification. Not unless your are running the tractor & dyno at the shoreline of the Dead Sea while burning E85 fuel.
AW Puller
06-21-2007 05:57:06
"New 70" sounds like a graduate of the "Chads school of dyno reading"
105EB
06-21-2007 05:06:59
B & D, you are forgetting that the laws of physics don't apply to tractor pullers. He didn't come here seeking information, he wanted his ego stroked, he's not happy because nobody's telling him how wonderful he and his tractor are.
New70
06-21-2007 08:21:30
 Re: All fuel 70 hp in reply to 105EB, 06-21-2007 05:06:59
Well, isnt pulling a sport of ego?
buickanddeere
06-21-2007 06:12:47
105EB
You are so correct.I can find the obscure but miss the obvious that's in plain sight.
b&d
F-I-T
06-21-2007 07:02:19
 Re: All fuel 70 hp in reply to buickanddeere, 06-21-2007 06:12:47
It's tough to convince someone if you carry 5 gallons of water up a hill in a minute, or you can carry 10 gallons of water up a hill in 2 minutes, that you did the same amount of "work". He never asked me what my 70D makes on the dyno....which depends on how much smoke you want to use on the local 'skeeters! I like mine at 51hp, no smoke, still more power than I have needed for the meager weight it is at.
I had never taken the time to read the Nebraska test for the 70D and it really surprised me when I did the other day to find that for its rated full of whatever many pounds, they put 1800# of ballast on it, from around 7,000 shipping, to 9,000 with operator. Then I thought a bit, and that was probably about right back in the day when we worked it on loads like 4-14's (which I always thought was too much). It was a much more pleasant day when you just pulling a cultimulcher and a drill.
Frank
