JD 224T timing
Andzs
06-19-2007 23:01:06
Can somebody help me how to set up the JD 224T timing? I had to take off the binding unit for repair. Now can't set it up. When I turn baler manualy it stucks in.
Tx Jim
06-22-2007 05:18:42
 Re: JD 224T timing in reply to G/MAN, 06-19-2007 23:01:06
Andzs said: (quoted from post at 11:02:39 06/21/07) Thank you very much Jim. I really value your assistance.
Andzs,did you get the baler in time? Jim
Tx Jim
06-21-2007 04:15:33
 Re: JD 224T timing in reply to Andzs, 06-19-2007 23:01:06
Bring plungerhead rearward on compression stroke by turning flywheel CCW,trip measuring wheel to engage knotter,when needles are just stating up in bale chamber and are even with the channels that are in bottom of bale case,the points on face of plungerhead face should be even with needles. If adjustment isn't correct R&R chain that is at rear and recheck timing. HTH,Tx Jim
Andzs
06-21-2007 08:02:39
 Re: JD 224T timing in reply to Tx Jim, 06-21-2007 04:15:33
mjbrown
06-20-2007 03:39:52
Do you have an operators manual? If I was with you and had a book I could and would help you . You can't do it with out a book.
Andzs
06-20-2007 08:58:25
 Re: JD 224T timing in reply to mjbrown, 06-20-2007 03:39:52
Unfortunately I have no operator's manual and it seems for me impossible to get it.
Bob
06-20-2007 13:03:48
 Re: JD 224T timing in reply to Andzs, 06-20-2007 08:58:25
Where are you located?
Andzs
06-20-2007 22:43:22
 Re: JD 224T timing in reply to Bob, 06-20-2007 13:03:48
I am in Latvia (Eastern Europe)
