Gasket needed..!!
Clyde Scott
01-13-2000 11:57:11
I need a gasket for the upper water pipe on a 1950 JD "B".. Deere no longer sales this gasket by itself..I can purchase a kit that containes it but dont need to pay $50.00 for one gasket. The JD part number is B2609R For 201000 SN's up..Any help appricated.. Clyde Scott
50boy
01-14-2000 20:12:33
 Re: Gasket needed..!! in reply to Clyde Scott, 01-13-2000 11:57:11
A trick I learned when making bolt holes is to cut a small x before putting the ball bearing or ball peen hammer over the hole. This keeps from stretching the surface around the hole.
Clyde Scott
01-13-2000 18:04:53
Thanks guys... it looks as if making it is the way to go.. Thanks for all the advice and Happy New Year to all...
clooney
01-13-2000 13:46:51
Clyde, I don't have my "B" parts book handy,is that a paper gasket or an "O"ring?
Clyde Scott
01-13-2000 15:42:42
 Re: Re: Gasket needed..!! in reply to clooney , 01-13-2000 13:46:51
Clooney:
Thanks for your response.. This one is paper.. I have one that came in a set that I got from somewhere but it is for an early styled B.. Beleive it or not, They changed at SN 201000..
As for "WWW'S" post, Yes I couild make one but like doing things right when I can..!!
zane
01-13-2000 17:00:36
 Re: Re: Re: Gasket needed..!! in reply to Clyde Scott, 01-13-2000 15:42:42
Clyde: You could make a perfectly good joint with high-temp silicon, out of a tube. But, if you're too particular to use such shortcuts, get yourself some paper gasket material from the autoparts store. Pull your part off and position it in a vise with the gasketed surface up. Use a ball-peen hammer to cut the gasket material over the part. Makes perfect gaskets--even the holes. Nobody will ever know it wasn't store-bought.
Tugboat
01-13-2000 17:34:02
 Re: Re: Re: Re: Gasket needed..!! in reply to zane, 01-13-2000 17:00:36
Clyde; You're right. That ball-peen hammer works well at making gaskets. A friend at work showed me another trick to make the holes real nice too. It involves placing a ball bearing over the hole and hitting it with the hammer. Just make sure the bearing is larger than the hole. Regards; Tugboat
clooney
01-13-2000 16:47:28
Clyde, you can try [email protected] he has a lot of NOS parts,but you will probably have to make it if J.D. doesn't have it. You can make a real nice one if you use gasket meterial from the local auto parts store.
ML Haberichter
01-13-2000 16:03:28
Actually I agree with www. Growing up I helped my dad and granddad cut many a paper gasket from a cereal box. Just the right thickness and they work and fit perfectly.
Redneck
01-13-2000 16:59:09
 Re: Re: Re: Re: Gasket needed..!! in reply to ML Haberichter, 01-13-2000 16:03:28
I have to agree. I make most all of my on paper gaskets, they fit better that way too.
www
01-13-2000 13:28:03
Make one.
