1st reduction cover full of oil on 530
fixerupper
06-19-2007 14:06:39
A friend of mine has a 530 that fills the 1st reduction gear cover clear full of transmission oil. He told me it was coming out around the clutch pulley and that the transmission oil level goes down and the reduction cover oil level goes up. He's very familiar with the 2cyl tractors and is good with wrenches but this has him stumped. He took the cover off, and everything looks fine. He will pour a little oil in the tranny and it will seep out around the PTO input shaft bearing, so I assume that bearing acts as the cover drain to keep the oil the same level as the trans. oil. I looked at it too and everything looks normal from the outside. Does anyone know what's going on here? Sorry about the long-winded story. Jim
machinery-man
06-19-2007 19:22:55
 Re: 1st reduction cover full of oil on 530 in reply to fixerupper, 06-19-2007 14:06:39
also the power trol seal can fail allowing that oil into the transmission...
fixerupper
06-19-2007 20:01:01
 Re: 1st reduction cover full of oil on 530 in reply to machinery-man, 06-19-2007 19:22:55
I really hate to doubt this man, because he has owned Deeres and repaired them himself for more years than I've been alive, but overfilling was the first thing to come to my mind too. He said the engine oil level has not gone down, and he is the kind of guy who does check fluid levels regularly, and he does know the difference between engine oil and gear lube.
The Power Trol seal idea sounds interesting. I'm gonna bring that up to him. He did mention the oil level going down in the tranny, so that might rule out the bad seal theory. Sometimes when you go back and talk to the person a second time more of the story starts coming out. Thanks for the info. Jim
machinery-man
06-19-2007 18:42:48
I might suspect a bad engine seal allowing engine oil to fill up the transmission. Be sure to check you fluid level there.
Mike M
06-19-2007 18:22:05
There is a bolt with an alum washer for a seal on the LH side of the tranny case about half way up this is the oil level. Kinda down from the brake assy. If your engine RH oil seal is bad it will pump oil into there.
dds-inc
06-19-2007 15:52:54
too much transmission oil would do this. You're only supposed to have a certain amount in there, so that might explain why it's dumping out the clutch.
