2 cyl diesel injector timing.
Earl-IL
06-19-2007 08:45:56
What is the best 2cyl diesel injector timing. I know about the marks . But TDC is not always TDC on the taper lock & worn splines. Thanks Earl
F-I-T
06-19-2007 08:55:31
 Re: 2 cyl diesel injector timing. in reply to Earl-IL, 06-19-2007 08:45:56
TDC isn't where you time them any way. The mark is #1 INJ. and #2 INJ. If you have access to an old flywheel (I don't carry one with me on the road), you can measure the marks from the TDC reference mark and make new marks on your talerlock, which should not be moving again... But I would start out by pulling the #1 injector, roll it up close to #1 TDC, then use a long point dial indicator through the hole agaist the piston top to find DEADCENETER, and mark it for posterity. Then you can back track and remark your two injection points. Be as accurate as you can...it makes a difference.
Frank
Earl-IL
06-19-2007 12:32:56
 Re: 2 cyl diesel injector timing. in reply to F-I-T, 06-19-2007 08:55:31
Yes I know the injector isn't timed at TDC. I have found the Taperloc & the Deere flywhheel are not same exact dia. I didn't have a Deere flywheel to go by. I have found a Deere flywheel and measured the # 1 inj timing and broke that down in degrees from TDC. I just thought someone knew what the degree of timing was. Sorry I didn't make that clear. I have that now. Thanks for the reply. Earl
mjbrown
06-19-2007 10:21:40
Since the injector pumps are run by the cam shaft which is timed in the gear train behind the flywheel, isn't the timing pretty much carved in stone and not adjustable?
F-I-T
06-19-2007 11:25:21
 Re: 2 cyl diesel injector timing. in reply to mjbrown, 06-19-2007 10:21:40
And since he can't "see" the correct position of the mark on the flywheel, which is indexed to the crank, which is driving the cam which has a mark that he cannot see.....
Blksmok
06-19-2007 10:27:39
MJ...the "push rods" that run between the cam followers and the pump are adjustable.
mjbrown
06-19-2007 12:34:58
 Re: 2 cyl diesel injector timing. in reply to Blksmok, 06-19-2007 10:27:39
True but that doesn't change the timing of the the peak of the cam lobe coming over center. The adjustable pushrod keeps the register mark in the little window on the pump. Setting the pushrod long moves the mark too far forward. Perhaps it reaches cracking pressure sooner but that seems like an iffy way to advance the injection timing and risks pump damage.
F-I-T
06-19-2007 14:15:42
 Re: 2 cyl diesel injector timing. in reply to mjbrown, 06-19-2007 12:34:58
MJB:
"Perhaps it reaches cracking pressure sooner"
Ain't no perhaps about it. That is the typical method for a unit pump/injector. If the pump(s) were mountd in a common body so that they could not part in stroke and time from each other, maybe you could get by with one register mark. Then you could "time" it based on the high point of the cam lobe, but here, since he can't see the lobe, can't see the cam timing mark, can't see the original mark on the crank relative to the flywheel "inj" mark, what else is there to do? The valves run off the same cam and you "time" those to have x lash so that the cam lifts them so high for so long. If you tighten the lash down, effectively lengthening the pushrod, the valve opens too early and stays open too long. Same for the pumps, so I'm not sure I get that it was a cheesy way to do it. They are independant units, albeit coupled on a common rack, but to get them to both lift the same relative to the cam and crank, the adjustable plunger rod seems to me to be the easiest method all around. It sure has worked well for years, provided you have a flywheel that is the right size with the right marks....
buickanddeere
06-19-2007 17:40:16
 Re: 2 cyl diesel injector timing. in reply to F-I-T, 06-19-2007 14:15:42
I met an old JD engineer at the 2005 NY Expo. He mentioned that they had a problem for a while on the assembly line. About 1/4 of the pumps were getting smashed from the pump having the piston shoved too far down it's bore. Albert was telling us about a diesel timing light. A pressure sensor is strapped to the injection line. The light flashes at the very start of the injection event. If every engine had the true TDC & injection marks located and marked on the flywheel. I suspect some would be a fair ways from the factory cast marks.
F-I-T
06-19-2007 17:50:31
 Re: 2 cyl diesel injector timing. in reply to buickanddeere, 06-19-2007 17:40:16
B&D, I have such a device. It was a Snap-on unit, and it was a vibration transducer that I used on my VW Rabbit Diesels back in '78-81. It's in a box somewhere. It generated the impulse to fire a conventional timing light. If you ever get your hands on a VW Chilton's or better yet, an authentic VW Shop manual (I remember they used to cost $20!), it shows the mechano-electro-vibrameter and a timing light. It worked pretty good, but after I used it several times, I found the their dial indicator to measure the pump plate rise method was so close you couldn't beat it. So, I stayed with static timing. I might have to break that thing out and try it on the 70, or my 855. Maybe I could wire it into a servo and have electronically controlled injection timing.....
mjbrown
06-19-2007 15:01:45
Got it. Thanks
Mike M
06-19-2007 09:49:33
I thought the book gave those measurements ? maybe not ? I do know it shows how to make a spring loaded rod to use a dial indicator against.
For sure start out with your own marks. And use a square to transfer the reference mark from the case over to the flywheel as you can get pretty far off with the eyeball method.
