36 JD B and prewar D's
buzz36
06-18-2007 21:36:32
folks I have a JD 36 B tractor and it has the two lever tow speed trany wanted to know if the later unstyled units witch has the threee spedd trany have any more road speed??
Also like info on the JD d model as I may be seeking one to restore or find a god running unit to enjoy how hard are parts for the pre war D's to come by like carbs and mags as most I found are missing these? also any idea of road speeds of the pre 35 witth e two speed trany and the 35 up to 40 withe 3 speed trany?? I want a pre war D so that is the info Im seekings
thanmks in advance
bob trmp nv
WeirdDeere
06-19-2007 23:44:04
 Re: 36 JD B and prewar D's in reply to buzz36, 06-18-2007 21:36:32
You can get about any part you would need for any of the Ds. Just beware, the earlier original brass carbs and the early type magnetos are getting pricey! You can find more modern replacements that are SLIGHTLY cheaper if you don't care about originality.
If you go for a 1935? or later (when they went to three speeds) it becomes even easier to find parts, as the D wasn't changed mechanically much from then to the end of production in 1953. There was a change to the mag mount (1937) and a different carb, but really that's about it.
Any D you buy, no matter the year, don't plan on getting anywhere fast! The two speeds were slow and slower. The three speeds were slow, slower, slowest. The three speed Ds were faster, up to about 4 MPH? Optional gears could get it up to 7.5 MPH. Still not very fast.
Brandon
zwr
06-19-2007 17:43:11
My 39 A has the two levers. It tops out at about 5 mph.
