Grinding Noise in PTO in JD-A
CWT
06-18-2007 19:26:03
I have a 1950 A and when I put the tractor in nuetral and I engage the PTO there is this awfull load roaring noise like metal grinding against metal. When I disengage the PTO , the noise goes away. Now if I put the tractor in gear I hear the roaring grinding noise no matter if the pto is engaged or not engaged. Can anyone tell which bearing or bushing this could be , do I have to take all the transmission gears out before I can fix it?
RalphinWI
06-20-2007 18:34:43
 Re: Grinding Noise in PTO in JD-A in reply to CWT, 06-18-2007 19:26:03
Our A has had a buzz in the PTO since new (Nov. 46. Consequently, I have never given it a thought. Having raised the question I would suspect that our buzz is the chatter of the pressure relief valve. I have other fish to fry in the next few days, but intend to make sure the rockshaft is in the lowered position (counterclockwise when viewed from the right side of the tractor), then see if the sound disappears when the control lever is pushed forward. I know in either the late 50's or early 60's Deere was spending somew mone on quieting hydralics, and in the far reaches of my mind valving was one area of interest.
Mike M
06-19-2007 05:38:21
Sounds like it is down in deeper like the pto bevel gears and or countershaft cluster gear.And I'm sure that one in the reduction cover can use some attention too as it is very common to be bad or loose in the housing.
dds-inc
06-18-2007 20:01:31
Listen closely to the first reduction gear housing. I have a suspicion it may be in there.
