110 Starting Rough...
hoff
06-18-2007 15:46:46
Guys...
I've got a '74 110 w/a 8HP Kohler. Recently it's been starting rough. Today when I went out, I turned the key and it just gave a whining sound like the starter was turning but the battery was dead or something. Then after 2 more tries it kicked right up without choke. It did puff a couple black clouds as it was reving up...once it was going, it's as good as gold, no smoke, nothing. I just changed the oil yesterday to Pennsoil 30 weight and I added a little Marvel Mystery Oil, but I doubt any of that has anything to do with it. Any thoughts? Anything I could test, add, adjust, etc? Thanks guys...
GeorgiaHayFarmer
06-18-2007 16:24:46
 Re: 110 Starting Rough... in reply to hoff, 06-18-2007 15:46:46
Whens the last time it had a good tune up? Points, Condensor, Spark Plug color? Good gas? etc...
Scott
F-I-T
06-18-2007 21:29:28
 Re: 110 Starting Rough... in reply to GeorgiaHayFarmer, 06-18-2007 16:24:46
Air cleaner, plug wire...
hoff
06-18-2007 16:45:11
Points...I dunno...gas is new...condensor, plug, coil, selenoid, starter, & air filter all new last year.
F-I-T
06-19-2007 08:49:35
 Re: 110 Starting Rough... in reply to hoff, 06-18-2007 16:45:11
Wasp nest in the mag gap, raccoon pee on the aircleaner...a year is a long time. I"ve seen a lot go bad in a year. Fuel pump diaphragm, kids put a handful of dirt in the tank, screen in the tank is cloged...
Rule out the fuel system first. Remove plug, ground spark so no explosion, remove fuel line from carb and check for good fuel delivery. I can"t remember on a 110 with it"s high-up tank if it has a fuel pump like the 214 or not. If so, crank engine to determine that fuel delivery is sufficient. If not, pull line and watch it for a length of time in case it starts to slow from a clogged fuel cap vent hole.
If all is good, check the ignition. Good spark at all times, points can get a oxide film on them over the course of a long humid spring. It still sounds like a basic tune up problem, at least to me. Sounds like it started after you changed the oil. Did you put too much in?
Frank
