G carb.?
Scott's B haven
06-17-2007 18:49:49
I'm helping a friend with his G it was running good until today when he started it up and it would not stay running with out the choke half pulled. I thought a good cleaning would help.
So he brought the carb to me, I took it apart
and used my #40 and #53 drills to clean all the little passages, but the carb looked real clean.
My ? is these drills are for my B's what size do I need for a G? Do you think dirt is the problem or a settng in the carb wrong?
Any help with is greatly appreciated.
Thanks, Scott
Mike M
06-18-2007 05:15:55
 Re: G carb.? in reply to Scott's B haven, 06-17-2007 18:49:49
On those G carbs. there is an extra hole in the stem to let more fuel in besides the one the load needle screws into. Look closely at the bottom accros from where a brass plug is.
Pappy
06-17-2007 20:33:24
Are you assuming that the carburetor is clogged?
What about fuel flow from the tank-through the sediment bowl-through the line-through the filter and into the carb?? I would check this out for sure.
Rusty Junk TX
06-17-2007 20:20:24
Make sure the points and condensor in the magnito or distributor are in good working order. They can make you think that you have a carburator problem.
Marcus
Mike M
06-18-2007 05:14:10
 Re: G carb.? in reply to Rusty Junk TX, 06-17-2007 20:20:24
I had a model 60 give the owner fits like that ,turned out to be a bad condenser. It sure acted like a bad carb.
jdjack
06-17-2007 19:45:39
Did you pull the nozzle out and clean it?
Scott's B haven
06-18-2007 02:09:29
 Re: G carb.? in reply to jdjack, 06-17-2007 19:45:39
fuel is coming in good, and nozzle is clean.No rust to speak of.
