530 JD PTO clutch slips
George Sloan
06-17-2007 16:12:23
Hi!
Thanks for your help. This is my fourth attempt at sending this response. Now I�m starting a new thread. I tried to reply to messages in the thread but I kept getting an error message. We made the adjustment to the pto. My neighbor had a heck of a time removing the mounting bracket for the 3 pt hitch. He called it an �elephant�s ear.� Now that green and yellow lemon is running fine. In another message of this string, someone (three letters starting with an F) mentioned if we are using the correct fluid. I don�t know. A manual he has for a JD 730 recommends using 10 W oil. Does this mean 10 weight engine oil? We have universal hydraulic/transmission oil and 15-40 WHD oil we use in the engine on hand. Besides the black color, the oil that came out didn�t look anything like engine oil.
Now for a totally unrelated problem. My neighbor drove through some well placed gofer holes in the hay field and cracked the front bolster. It had been welded before and was good enough for his previous tasks. Here there are more hills and stones and rough ground. I�m afraid we need to find one with no previous cracks. I looked on this web site and it shows 2 different bolsters. Which one am I looking for and can I find the part number on line?
Thank you very much for your time and help.
F-I-T
06-17-2007 17:50:34
 Re: 530 JD PTO clutch slips in reply to George Sloan, 06-17-2007 16:12:23
Yes, it means engine oil. I think if you read closer it might even say elsewhere to use the same weight and grade oil in the pto case as you use currently in the engine. But in any case, they are talking engine oil, though some folks use modern hydraulic fluid in them, but since delamination of those expensive pto clutch facings is always a concern, I opt to use the oil that the book called out. My disks are still going strong since 1970, so that's my testimony.
On the "bolster". Do you mean the assembly that holds the two front wheels? Or the entire front end casting that goes clear back to the engine block/main case seam? If you mean the assembly that holds the front wheels, do you have the Roll-A-Matic, the type where the wheels are attached to two offset knuckles that can move in opposite and equal directions, or the solid axle front end? Got a photo? That would "steer" you in the right direction much faster. Got power steering?
Generally if you cannot post a reply to a message, there is something in the grammar that the imbedded curse checker sees as a bad word, or a url that the owners of this site do not want repeated or advertised. The next time something like that happens, try backing up and eliminating a line at a time until you find the offending text. Then you'll be able to trim it out, or clean it up.
Frank
George Sloan
06-18-2007 08:57:30
 Re: 530 JD PTO clutch slips in reply to F-I-T, 06-17-2007 17:50:34
Thanks for clearing up the oil question. Sorry about leaving out most of the details about the front end. It's a wide front end with power steering. The main frame of the tractor is fine, but the part that the front end pivots on.
Thanks again George
F-I-T
06-18-2007 09:59:19
 WFE Bolster picture in reply to George Sloan, 06-18-2007 08:57:30
third party image
I would think that for a general row crop type 530 with a wide front end that you have what is called the "square" type. This one has a square cross section shaped casting that holds the round tubes that hold the knees (the down portions where the wheels attach). Someone out there is reproducing these. Look in Two Cylinder magazine or wait for someone here to get you the contact info. The part is not cheap, but neither is that front end. Even more expensive is the repair when you roll that front end under the tractor, and you just hope it isn't in road gear at the time.....
WeirdDeere
06-17-2007 16:26:51
The book says 10W engine oil. I've used 10W30 in mine. 15W40 MIGHT be ok, I'm not sure...
Brandon
mjbrown
06-18-2007 04:27:49
 Re: 530 JD PTO clutch slips in reply to WeirdDeere, 06-17-2007 16:26:51
I thought it said 10W non detergent oil.
buickanddeere
06-18-2007 20:01:19
 Re: 530 JD PTO clutch slips in reply to mjbrown, 06-18-2007 04:27:49
Can't go wrong with a trans/hydraulic oil rated for use with wet clutches.
