Alt for JDH
Doug Sr.
06-17-2007 08:56:44
My JDH has a 12 volt alt. It has a pos and neg terminal on it. It also has a F and R trminals on the back. They have the F conected to a switch. The R is not conected. Is there any other way on the H to conect it without using the on off switch? In time I will change it back to six volt but for now I will run it like it is. Thanks Doug
Doug Sr.
06-17-2007 15:32:18
 Re: Alt for JDH in reply to Doug Sr., 06-17-2007 08:56:44
The F and R terminals are like thie 11 not -- all they had was a switch going from the batery to the F wire.
Doug
Bob
06-17-2007 17:39:43
 Re: Alt for JDH in reply to Doug Sr., 06-17-2007 15:32:18
If it is REALLY the older-style 10DN, as it seems to be, it has NO internal voltage regulator.
The way it is set up now, when the switch is "ON", the alternator is simply "full-fielded", and charges at is maximum rate.
To have it function properly, with voltage regulator control, you'll either have to add an EXTERNAL voltage regulator to the alternator you have, OR swap it out for a "10SI style", WITH a built-in voltage regulator.
Doug Sr.
06-17-2007 15:01:16
The one I have looks like the diagram not the picture. All I see is the letters and no numbers on it. Doug
Bob
06-17-2007 11:44:56
First, we need to know WHICH alternator you have.
Declo 10SI:
Third Party Image
Delco 10DN:
Third Party Image
Take a GOOD look, and see which photo matches what you have, and let us know.
The 10SI "carries over" the "R" and "F" markings from the 10DN, but will also have a "1" and a "2" next to the terminals. The 2 terminals MUST aslo be "flatwise", like this: - - to indicate it has an internal regualator. The VERY EARLY 10SI's could have 10DN internals, with NO built-in regulator, and the terminals like this:
