Another question for Steamer
RonMC
01-13-2000 00:24:57
I'm about to fit the blade to my MC, and have discovered an OOPS ! The front cross-bar is an inch longer on the right side, and I have the extra inch on the left. It won't take long to change over, as my wife kindly bought me a new compressor, but my question is in lining up the front idlers in the absence of legible marks. The last time, I ran lines over the rear sprockets on top of the teeth, and fastened them to the shop wall, maintaining the same distance, and lined up the idlers that way. Is there a truer way you know of to keep things in a good starting position ? I'm sure it will need a little fine tuning in the driveway, but would like to keep this to a minimum. Thanks for any advice. RonMC
Steamer
01-16-2000 10:26:49
 Re: Another question for Steamer in reply to RonMC, 01-13-2000 00:24:57
The easiest way to do this is to follow the track alignment procedure Deere has in the service manual. There are quite a few steps involved, and I think it's too much for a post or e-mail. You can use the MC, 40, 420, 430, 440, etc manual as the procedure doesn't change acroiss the family. If you get stuck, I could make up a copy of the section out of my service manual for you.
Basically, you need to set the track carriage to the mark on the main cross bar. That gets the carriage aligned with the sprocket. Then you need to adjust the front idler adjustments so that the ribs are centered on the track chain. To measure that, you'll need to pull off at least one track shoe on each side. If you have the snow shoes, with the oval hole in the center, it's possible to make the measurement without pulling a shoe off.
RonMC
01-17-2000 11:40:05
 Re: Re: Another question for Steamer in reply to Steamer, 01-16-2000 10:26:49
Guess I better go get the full manual. Have been running on I&T, but not well covered in there. Will have to go check measurements on another MC, as my marks are not well defined. Thanks for the info. Oh, by the way, am leaning to very early IH as the mystery machine. Have talked to my friends hunting companion, and he says rears are higher, but not as high as the seat. This probably indicates IH or Cletrac of some sort. More when I get it, Later, RonMC
steamer
01-18-2000 10:37:02
 Re: Re: Re: Another question for Steamer in reply to RonMC, 01-17-2000 11:40:05
I'd be lost without my JD manuals. The I&T ones are fine for basic maintenance tasks, but they do fall short when getting into the less common repairs. The JD parts manual is also a great help with all those nice exploded view diagrams in it. I find that between the two books, little is left out.
One thing though, you'll find that this series of machines' manuals build on the earlier ones. I.E. if you're into a 420, you find yourself needing the 40 and M manuals as well. If a topic is covered in the M book, they leave it out of the later ones. The idea seems to be that if you're into this much of a repair, you're a dealer, and have the entire series at hand. Of course, each successive series had changes from the prior one, so there was plenty to print up without duplicating sections that were unchanged.
I mention this only because I've run across others that didn't know this and were missing data in their later manuals (and so many folk read this board) that this might come in handy for someone...
