JD 4720 power
gas2184
06-16-2007 20:35:31
I am considering buying a 1 year old 4720 for utility use including plowing with a 3 bottom plow. I think this tractor is rated at 58 hp (diesel) but does it have enough power/torque to pull a plow? What is it worth?
gas2184
06-17-2007 05:31:22
 Re: JD 4720 power in reply to gas2184, 06-16-2007 20:35:31
Can you expound on your comment?
buickanddeere
06-16-2007 21:53:31
It all depends.
buickanddeere
06-17-2007 12:14:42
 Re: JD 4720 power in reply to buickanddeere, 06-16-2007 21:53:31
Depends on plough bottom width, plough manufacture, intended ploughing depth, intended travel speed, mounted, semu-mounted, trail type, type of soil, soil moisture, hills if any, cover crop if any, tractor tire size, tire type, tire inflation, tire tread syle, front/rear ballast, transmission option(s)..... ..... ..... .....
Mike M
06-18-2007 08:05:20
 Re: JD 4720 power in reply to buickanddeere, 06-17-2007 12:14:42
Afterall they do make small plows for garden tractors ?
If you are just going to do smaller fields or large and small gardens look into a 3pt. roto tiller these really work well. Sometimes in a single pass your done ready to plant.
