720 gas Pwr steering
Ron Muhlenkamp
06-16-2007 09:15:28
My 720 with P/S likes to turn left and sometimes ,doesn't like to turn at all. Half the time it works very well so I suspected dirt in the fluid rather than chipped gears. Drained the fluid which was clean, no help. The manual says move the valve housing fore or aft but the bolt holes are round, not slotted. What am I missing. Ron
bigblock
06-16-2007 10:20:03
 Re: 720 gas Pwr steering in reply to Ron Muhlenkamp, 06-16-2007 09:15:28
Mine did this too,but the bolt inside the housing that hold the tang to the sliding valve was loose.It was about to fall off inside.Anyway then I had to adjust the fore and aft position of the valve.
F-I-T
06-16-2007 09:49:57
To center the actuator valve, bump it A LITTLE (a few thousandths) at a time fore or aft until the poppet is centered in its travel path and the wheels tend to sit straight forward when there is no steering wheel motion input. The acutator valve is the outer housing, mounted on top of the worm housing. It has the steel tubings attached. It has elongated holes, not much becuase you don't need much, and the housing rides on a couple of 1/8" or maybe 5/32" dowel pins. You can see the guiiding slots for those if you look closely at the front edge where it mounts to the worm housing.
Frank
John T
06-16-2007 11:44:47
 Re: 720 gas Pwr steering in reply to F-I-T, 06-16-2007 09:49:57
Yo Frank, Was it you or Clooney who once posted that picture sort of describing what you said?? I have a copy of it if you dont already..... .
John T
