Help in starting widows J.D. A
sheppp
06-15-2007 19:35:39
I am new to forum,and need your help,widow, who lost her husband last fall asked me to help start her late husband"s late model A. She had tried, when I got there, and when it turns over gas, shoots out of exaust, If it is someting I can do, let me know, her young son, put in new plugs. Thanks Fellows!
RalphinWI
06-16-2007 07:59:52
 Re: Help in starting widows J.D. A in reply to sheppp, 06-15-2007 19:35:39
If taking the plugs out to clear the gas, DISABLE THE IGNITION!. I know of a case were gas sloshed on onto ones pants, and then was ignited by the dangling plug wire.
greenmech
06-15-2007 22:04:50
Also change oil in the crank case as gasoline is probably in there too. Ron Mn.
dds-inc
06-15-2007 20:47:13
I will be glad to offer assistance here.
This is obviously a fuel issue, in which the gas in the cylinders came from a leaky needle valve and seat. I am recommending that the fuel be drained out of the tank and the tank cleaned out some to remove debris. Make sure the sediment bowl (that glass thing under the tank) is functioning properly. You should pull the bowl of the carburetor off by taking that big nut off on the bottom. You will need a new needle valve and seat. Also check and make sure that the float does not have gas inside of it (shake it to feel any sloshing).
After reassembly, you should check and make sure you have a good spark by holding the plug and wire to ground and cranking the engine. It should be nice and blue.
This is about all I can do for you until you provide feedback.
Lee B
06-17-2007 04:13:44
 Re: Help in starting widows J.D. A in reply to dds-inc, 06-15-2007 20:47:13
How odd is it both jimtnv and dds-inc talk the same talk? Well with "wrench in hand", it"s plainly obvious you have never really cleaned out any gas tanks if you don"t consider it a drastic undertaking - which it IS. And the only way to do it properly is to turn the tank upside down for a though flushing.
Further, since you can"t seem to actually read the advice I gave, I have no use for you at all. You"ll soon get your feathers clipped but good in this group mr. magnanimous.
dds-inc
06-18-2007 18:53:46
 Re: Help in starting widows J.D. A in reply to Lee B, 06-17-2007 04:13:44
well, I could give two poopy farts for your advice.
P Browning
06-17-2007 08:01:42
Lee B -- Give it a rest already. Just because a man says he is new to the forum don't mean he isn't savvy to the tractors routinely discussed here.
Besides -- two points to think of here - - -
1. This is a place where someone can ask a question no matter how silly I or someone else may think it is.
2. Just because I see a response that doesn't suit my fancy, so long as it is not wrong, I have a choice. And that choice range runs from being sarcastic and downright mean on the one hand to keeping quiet on the other! And if these limits are the ONLY two options I can think of, I hope I choose the latter.
And so let us all get back to tractoring and enjoy a peace-filled Fathers Day weekend. (PatB)
Lee B
06-16-2007 00:43:54
Your advice is bit free with the drastic measures where perhaps an easier fix is called for? Is the widow supposed to take the front end of the gas tank when they lift it over the exhaust pipe or does she get the heavy end? Perhaps she just left the gas on overnight which NO old timer ever does and that's the root cause of the "problem"?
And maybe she just wants to get it started so she can get the better price for it? And maybe sheppp really don't need to $$overhaul$$ nuthin?
I'm thinking sheppp really needs to get a Deere man on the case and in person since he doesn't seem to be one. The closest John Deere dealership should be able to name a couple of local guys with that same year/model of tractor that would be very pleased to help the widow get the tractor started for what ever reason she has for doing that.
Sheppp - don't try to become a Deere man overnight using the widow's tractor to learn on, it can be expensive and exasperating, for you and the widow. My advice is to get someone who already knows this stuff backwards and forwards - ask him to help.
jimtnv
06-16-2007 18:35:03
 Re: Help in starting widows J.D. A in reply to Lee B, 06-16-2007 00:43:54
A wrench will fit in anyone's hand. You don't have to take the gas tank off to simply drain it and flush it. A needle valve and seat assembly can be done by the average 16 year old. AND, holding a spark plug to ground while cranking is a century-old practice to see if there is a valid spark.
He has offered no harsh advice. In fact, telling 'sheppp' to take it to a john deere dealer is rather, an insult to his mechanical abilities and willingness to help the widow. Not to mention that john deere dealers charge outrageous amounts of money for a service call. Yeah, stick the widow with the bill.
What, then, is considered an "easier" option to get this tractor running? Talking to it? Patting the side of the hood and saying, "come on girl, start"?
You obviously know NOTHING about tractors due to the denial of 'dds-inc's SIMPLE procedure to diagnose a tractor.
dds-inc
06-16-2007 18:24:06
Drastic? What the heIl is so drastic about putting a wrench in his hand and cleaning out a fuel tank??? It's not like he's going to to a major overhaul, you pompous b*stard!
