4010 Tie rod ends
Gary Halcom
06-15-2007 18:53:57
How can the tie rod ends be tightend to the top of the spindle so the slack can be taked out. Can washers be added under the bolt attaching the tie rod end to the spindle.
Thanks
msb
06-15-2007 21:13:20
 Re: 4010 Tie rod ends in reply to Gary Halcom, 06-15-2007 18:53:57
Link
Part #17 Probably not your model, but is this what you are talking about. I have got to learn how Bob transfers Deere parts pics. If this is it, the short answer is to replace the steering arm, though they are pretty salty.Guess you could cut some strips of metal and shim up the tapered splines. The arm usually wears out first if they are not kept tight.Cast iron is softer that the steel used in the spindle. Maybe someone else has a better solution?
zwr
06-15-2007 19:55:48
I did--on a 4020. I think they're the same.
You may have to look around a bit to find a flat washer with an ID big enough to slide over the end of the spindle without looking outlandish on the OD.
Or maybe just grind it off. Hmmm...
