36'b oil line routing
JDNPC
06-15-2007 11:16:20
looking for a diagram or picture of how the oil lines in the crank case are routed on a 36' b. some were missing when i disaaaembled and want to replace with all new copper. the manuals i have, don't show how to route them. which side of filter housing is the supply/ pickup and return ? thanks in advance.
CalJim
06-15-2007 17:36:38
 Re: 36'b oil line routing in reply to JDNPC, 06-15-2007 11:16:20
I would STRONGLY agree with machinery-man. Those lines run around the crankshaft without much clearance. You should be able to find a set without too much trouble. A used set can be inspected for loose fittings and resoldered if need be. My $ 0.02. CalJim
machinery-man
06-15-2007 12:16:58
I can tell you from experience you're in for a difficult job. The lines are specialty in nature and have unique fitting and couplers. I would suggest that you find a parts tractor that has them in tack. They have to be bent and routed to avoid the crank and other moving parts. Make it easy on yourself and find a used hulk.
