HELP PLEASE Deere 214 garden tractor cuts out when PTO engag
Nate S from Nor
06-15-2007 10:32:36
The engine cuts out every time I try to engage the PTO for the mower. I haven"t checked the spark at the engine, but suspect it may be a safety feature. I can see the blades start to move, make a few revolutions, and then stop with the engine. ANY advice is GREATLY APPRECIATED.
eMail:[email protected]
F-I-T
06-15-2007 19:45:22
 Re: HELP PLEASE Deere 214 garden tractor cuts out when PTO e in reply to Nate S from Northern MN, 06-15-2007 10:32:36
I had a 214 for many years and as was already said, I'd check the seat safety switch. Most by now are rusty and either open all the time or intermittent. You can unplug that and try a jumper in the connector and if it works, you'll need a new switch, as I can't recommend running with it jumpered, but that is up to you. There is also a switch on the pto lever if yours is an older type. Later they used an electric clutch with a dash board switch. The only other safety switch is on the gearshift and it is a neutral start safety. It's likely the seat switch if it starts ok and only cuts out when the pto is engaged. The design is that you must be on the seat, in neutral to start, and in the seat to engage the pto.
Frank
buickanddeere
06-15-2007 12:18:55
Cuts out or stalls?
JDNPC
06-15-2007 11:19:48
nate s, i would start simple with assuring the nuetral safety, seat and reverse safety switches are fuctional, then look for obstuctions on the underside of the deck. if everything checks out ok, you might have a bound up belt on the deck or a worn bearing/bushing, or maybe your pto has gotten hot and seized. remember to start simple.
