'41 A clutch disc timing
Scott Batts
06-14-2007 18:48:39
I have a '41 A with the clutch end of the crankshaft having the milled spline for the rivet to time it in. The problem is that the hub that I have does not have the rivet, nor has it ever. I assume that it was replaced with the newer hub. Is there anyway that I can count splines or line something up to make it in time.
Thanks
kendak
06-15-2007 09:08:43
 Re: '41 A clutch disc timing in reply to Scott Batts, 06-14-2007 18:48:39
right hand piston # [2] at TDC put center of clutch disk to the rear 9 o'clock position...Kent
Pappy
06-14-2007 21:50:33
Look at the clutch driver (hub) Mark the weighted section of the hub in the center with a marking pen. Now, rotate the flywheel to line up the timing mark at the 3:00 o'clock position. This is with the left piston at TDC. Now, install the clutch driver with the mark on the weighted side at the 3:00 o'clock position.
Bolt her down tight. That's it.
