6-3 POWERBLOCK HELP
MJN in OH
06-14-2007 18:26:53
After a days work we parked the 60 and the next day when we fired it up it blew water out the exhaust. We tore it down today and the fel pro head gasket showed no obvious signs of leaking. But the #1 cylinder was full of anti freeze. We have it at the shop now to get the block and head surfaces resurfaced. My question is could the sleeve orings be bad causing this. If so how can one replace these orings without destroying the sleeves. Also how can you tell if that would be the source of the leak. This engine was just rebuilt a year ago and has ran great until she blew water out the exhaust. Also does anyone have a John Deere block they are willing to sell. I am thinking about getting rid of this powerblock set up.
Mike Aylward
06-15-2007 12:54:35
 Re: 6-3 POWERBLOCK HELP in reply to MJN in OH, 06-14-2007 18:26:53
MJN, has the block been out and been to the shop before? If so, if the block was hot tanked odds are the rings are bad due to the process. I had one cylinder on my 70 that seeped through a pin hole in the sleeve at the very bottom of travel. I fixed it by mixing up some fiberglass resin and dropping it in the upper water pipe hole while the block was tipped up. I heated the inside of the block to get it warm and dry, poured in the resin, then let it set for a day or so. It's been working ever since without problems. This is on a pulling tractor so it gets "tried". While this may be too much of a "poor boy" fix for some I had quite a lot of money invested in the block and pistons so I tried to salvage what I had and have been very pleased with the results. To my estimation the resin has a little "give" which will help it hold better than a product which gets "bone-hard". Hope this helps. Mike
jd b puller
06-15-2007 10:14:50
KW block sealer available at Carquest is the best I"ve HEARD of. Haven"t used it myself. Probably won"t get the sleeves out without wrecking them.
ET
06-15-2007 05:16:02
I would check the head for cracks before I blame the block. It's cheaper.
James Chantry
06-14-2007 19:20:30
Had same problem with a 6-2 powerblock in a 49 model A. Determined it to be the o-ring at the head area of #1 cylinder. Found it by: pulling head, cutting a piece of 3/4" plywood the same as the head with cylinder area cutouts. RTV and bolted to block, filled water side, with mirror I could then see leak at about 7 o'clock position.
Fixed it by: Used liquid glass, Barr's head sealer. I left off the upper water inlet, filled block with water and liquid glass. Ran engine till water was just starting to boil, turned off engine and let cool, then ran again. Took two days of this to seal. I could see bubbles of combustion gas coming to water surface till it sealed.
This repair has lasted 1 year on a field working tractor. To replace orings means new sleeves and very costly - more than a new block and pistons. Of course could always sell the powerblock. Hope this helps.
buickanddeere
06-14-2007 18:38:10
I'll purchase the powerblock if you want. Was there new studs, nut & hardened washers used when rebuilt? Did anybody apply air to the cooling system and then the combustion chamber then listen and look for air and /or bubbles?
