140 Electrical Problem
Ron B in CO
06-14-2007 17:55:05
After I did a tune up (points, condenser, plug etc.) and charged the battery, I turned on the ignition key to find the ammeter pegging to discharge. Where do I start to trouble shoot this problem? Must have a dead short somewhere.
Bob
06-15-2007 02:26:52
 Re: 140 Electrical Problem in reply to Ron B in CO, 06-14-2007 17:55:05
Could the rectifier/voltage regulator have shorted, for some reason?
Was the battery completely DEAD, and could you have connected up the charger with the leads "swapped", charging the battery to reverse polarity? (YES, that IS possible.)
Start by pulling the connector off of the rectifier/regulator. Does the short "go away" when it's disconnected?
Ron B in CO
06-14-2007 19:01:37
Thanks for the suggestions. I disconnected the wire to the points (they were open at the time) and it didn't help. Next I disconnected the condenser, no help. Maybe a short in the wiring of the charging system and it is a coincidence that it shows up now. This is a tractor that I changed from electronic ignition to battery/coil ignition in 1991. Complete overhaul in 1993. Has been working fine till this spring when it hardly had enough power to pull itself, hence the tune-up. I like old things, but I'm starting to wonder why. I would rather work on an old 2 cyl. any day.
John T
06-14-2007 18:49:05
Ron,
If you had a near zero ohm (dead) short the ammeter would peg hard n full to - discharge buttttt ttttt it wouldnt be but just a lil while till a wire melted n you let all the smoke out..... ..
If when you turned on the ignition she swung easier over to maybe 4 amps discharge, that would be about normal for an ignition coil to draw assuming all was wired correct and the points were closed (which they usually are) and its a regular battery n coil ignition.
I agree with the Franksters comments that maybe the coil or points or their wiring is shorted somewhere buttttt ttt it makes a difference if she full pegs heavy (dead short) or a lesser amps discharge (maybe just the regular coil current draw.)
BUTTTTT TTT heres my problem in diagnosing this sittin here..... . If its a real low ammeter, like a 5 or 10 amp unit on some lawn tractors versus say a 20 to 30 amp ammeter like on a tractor, then it may "peg discharge" WITH ONLY MAYBE 5 AMPS WHICH ISNT A DEAD SHORT CUZ IF SO THE WIRE SHOULD MELT.
If you dont smell or see smoke in just a lil bit I think whatever the "short" is aint a DEAD SHORT but can still obviously be a problem UNLESSSSS SSSSS its a low range ammeter (maybe a 5 or 10 amp) which may just be normal coil current draw????? ??
This is a battery powered coil ignition correct????? I think thats what 140's used. If it were a lawn tractor magneto ignition all their ignition switch does is short out the ignition when OFF
Sooooo ooo it makes a difference of the ammeter range (5 or 10 or 20 or 30 amp) and what the actual amp draw is and Ima thinkin if it were truly a dead short you would have already let the smoke out n the wires would have melted.
Check the switch wiring and the coil n points wiring like the Frankster told ya, the ignition circuit is to n through the switch (when ON),,,,, ,,,,to and through the coil (maybe 3 ohms),,,,, ,,,to and through the points (when closed),,,,, ,,,to ground and the condesnor is in paralell with the points.
Let us know, try easy simple things first like switch n wires n coil n condensor n points correct wiring.
John T
Ron B in CO
06-14-2007 19:24:20
 Re: 140 Electrical Problem in reply to John T, 06-14-2007 18:49:05
I agree about the melting and smoking. The ammeter is 10 amps with a lot of area that is not scaled. Does that make sense? The needle pegs so hard that it hangs and needs a whack to release to center.
John T
06-15-2007 06:18:23
 Re: 140 Electrical Problem in reply to Ron B in CO, 06-14-2007 19:24:20
The peg you describe ABSENT smoking/melted/burned wires suggests to me perhaps a 10 to 20 amp discharge NOT a dead short but stilllll lll very serious. Since it happens when you turn on the switch right????? remove wires off its load side one at a time until you find the shorted circuit.
Once alllll the load side circuits are removed if you place an ohm meter on the R x 1 scale on ground and probe the individual wires with the other lead/probe, I would expect to find resistances in the vicinity of maybe 2 to much higher but NOTTTTT TTTTT like .5 or so ohms which would draw 24 amps n peg the meter.
I believe the rectifier block/module is a two wire in and one out, the two comes from the series of armature windings while the one leads to the ammeter I believe, its the DC charging output. The 2 wires from the armature (after remioval from rectifier) should read continuity but NOT any connection to ground cuz if so they are shorted. The output wire from the rectifier leads to ammeter and it should not have continuity to ground otherwise its shorted MAYBE THATS WHERE THE SHORT IS ID CHECK THAT WIRE !!!!! !!!!! !!!!! !!!!!
John T
F-I-T
06-14-2007 18:10:02
Did you by chance move or rotate the coil so that its input/output wire is grounded? Did you set the points on the wrong cam point and they are closed all the time grounding the coil full load? Is the wire from the coil to the points now touching metal? Is the condenser touching the hot wire under the cover?
Start by checking those three places, working back to the switch. Don't anything tunred on for long. The old brittle wiring won't stand that sort of current for a prolonged period. High current will roast those old dashboard ignition switches, too.
Frank
